Old 07-17-2026, 07:03 PM
tekheavy's Avatar
tekheavy tekheavy is offline
Default Are aftermarket hood tachs adjustable?
My hood tach on my '67 seems a bit off. Seems to be reading too low. Are there any adjustment on them? And if so, can it be adjusted while mounted on the car or will I have to take it off the hood?
Old 07-17-2026, 07:29 PM
einstein's Avatar
I recall when Padgett was repairing tachs, he used a graphite pencil to apply some graphite to a spot on the circuit board to tune the resistance. He said the factory reading was generally 200 RPMs off to read higher than actual engine speed. I do not recall where or how exactly but he had a meter reading the resistance and I saw it change to his desired spec.
This was close to 40 years ago and he's been gone 3 + years already. I did not commit the technical details to memory, obviously.
Hopefully someone else here has this knowledge.
And maybe this question would get more engagement in the Electrical forum.
Old 07-17-2026, 11:40 PM
70GS455 70GS455 is offline
Yes, the aftermarket ones usually include a potentiometer. You will have to remove the tach and unseal the top and bottom
Old 07-18-2026, 07:27 AM
tekheavy's Avatar
Ok, thanks. I will give it a shot before I put the car away for the season.
