Old 07-18-2026, 11:03 AM
joes455 joes455 is offline
Default Bam roller lifters
Anyone using Bam roller lifters?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 07-18-2026, 11:16 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Yes and we sell a lot of them. Never had a failure
Go fast, see Elvis!
The Following 3 Users Say Thank You to PAUL K For This Useful Post:
Old 07-18-2026, 04:24 PM
Dragncar Dragncar is offline
Get the DLC option.
IMO, this is the way to go, even for street guys running hyd roller cams.
Get a custom SR with BAMS and not worry about ticking lifters or a lifter failure destroying your engine.
Solid rollers sound cool and if you get top notch rockers with stud girdle or shafts your lash will not change all the time.
Old 07-18-2026, 05:38 PM
Gary H's Avatar
Gary H Gary H is offline
Yes. First class lifters!
Old 07-18-2026, 06:56 PM
ANDYA ANDYA is offline
I just got a set of BAM solid rollers from Paul K. When it comes to Pontiac engines he is one of the most knowledgeable people I have ever spoken with and he has very fare prices.
The Following 3 Users Say Thank You to ANDYA For This Useful Post:
Old 07-19-2026, 08:09 AM
Nacs Fab's Avatar
Nacs Fab Nacs Fab is offline
Im going to change over from Hydro to Solids soon so Ill give Paul my business!
69 Firebird - Angry Bird
455 with 84mm Torqstorm
The Following User Says Thank You to Nacs Fab For This Useful Post:
Old 07-19-2026, 10:12 AM
chuckies76ta's Avatar
So for street use, what is recommended. Bearings or bushed lifters? This is solids on a hydraulic cam. So this model? https://bamlifters.com/products/bam-...599bf353&_ss=c
950 Quickfuel.
Old 07-19-2026, 01:34 PM
Steve C. Steve C. is offline
Related thread from 2022....
Best bushed solid roller lifter ?
https://forums.maxperformanceinc.com...=bushed+lifter
I suspect some opinions could have changed over the years.
This posted here for interest only.
Old information here:
Old 07-19-2026, 01:54 PM
Take the time to read the comments made here....
https://www.facebook.com/EngineLabs/...8127353691393/
( Information provided in this post does not represent any endorsement and is offered for general interest only )
Old 07-19-2026, 04:12 PM
AG's Avatar
AG AG is offline
What is the consensus of running a SR on the street in terms of SR lifter type and longevity. I will be putting my race motor that uses Crower HIPPO lifters currently into my street FB and I am trying to decide to run my SR or use a RP HR I have. If a BAM SR lifter would work I'd get that.
Old 07-19-2026, 04:58 PM
Take the information here from 1999 with a grain of salt.....
Note that BAM does not recommend needle bearing solid roller lifters on the street.
https://bamlifters.com/pages/faqs
Back in 1999 Crower was tending to favor neddle bearing roller lifter for street duty.
However I suspect it might be combination specific at the time.
Fast forward to today and Crower is singing a differet tune !
" Crower recommends and builds bushed roller lifters for street use. Their EnduraMax series lifters utilize a needleless bushing and their High Pressure Pin Oiling (HIPPO) technology, which are designed to withstand the low RPM idle time and heavy load demands typical of street driving.Needle bearings inside traditional solid roller lifters tend to fail under sustained street use because of uneven loading and low RPM oil starvation. Crower's bushed lifters address this by distributing the load evenly over a larger surface area while continually feeding pressurized oil to the axle and bushing. "
Old 07-19-2026, 05:28 PM
AG's Avatar
AG AG is offline
I have read those threads previously (and thank you for always providing real world data instead of conjecture) and was hoping for some feedback from people running SR cams on the street for more than 1000 miles a year.
Old 07-19-2026, 07:10 PM
Maybe moving the subject to the street section might conjure up additional information and examples.
That said, this one within that thread I linked was an eye opener.....
"Yup, monitor lash, look closer at lifters if you see a 'decay' of adjustment. Considering the length of time, checking seat psi is a good idea too. I've run a number of SRs on the street without issues. The one engine went 225,000 miles."
HWYSTR455
As noted I worked with Tim at Bullet Racing Cams when I changed to my current solid roller set up. I did so for a less aggressive lobe profile and to reduce spring pressure.
Old 07-19-2026, 09:30 PM
Really combo dependent. Im not a fan of solid rollers for street use but we drive 6-10,000 miles a year. It would have to be such a mild lobe profile that accepted a light spring that I'm not sure it would offer much of a performance advantage over a decent hydraulic roller.
After Dad's bischoff engine ate 2 bushed crower solid rollers with pin oiling after just 3000 miles I got the impression 240 on the seats, while not a ton, was probably not friendly on parts for something driven on the street as much as he does, even with the tight lash that cam used. For what it's worth, Crower didnt have an answer for it at the time.
So I came to the conclusion a solid roller with possibly 180-200 on the seats would have a better chance of living thousands of miles on the street, but it would have to be a pretty mild stick to run those spring pressures. Springs appear to have a lot to do with how long the lifter survives. Too light can be a problem too. My thoughts from the failures I've seen anyway.
To each his own, ya just roll the dice and see what works. Plenty of good builders and cam experts that have a better idea of what works well and survives that might make you feel better about solid rollers.
https://youtu.be/XqEydRRRwqE
Old 07-20-2026, 12:46 PM
Jay S's Avatar
Jay S Jay S is offline
BAM DLC coated steel bushed lifters have been providing a pretty consistent 4X longer service life than the bronze bushed type in the same applications where service life is a factor.
Service life has not shown itself to be a factor with HR cam profiles using SR needle type lifters unless for some reason SR spring pressures are used. I am not aware of anyone that has used DLC Bam’s on a hybrid cam.
Old 07-20-2026, 08:08 PM
ponjohn's Avatar
ponjohn ponjohn is online now
Solid or Hyd?
Old 07-21-2026, 02:37 AM
They don't make Pontiac hyd rollers.
Old 07-21-2026, 07:59 AM
PAUL K's Avatar
With a the valve train failures nowadays we usually just go with their premium lifter. They're the same design the six second Drag n Drive cars use. Currently they're around $1100 a set and are bushed. They're needle bearing lifters are comparable to Crower and Isky are closer to $700. Those would be the recommended lifter for the solid lifter/hydraulic cam set up.
Go fast, see Elvis!
Old 07-21-2026, 10:29 AM
Jay S post is worth noting...
"Service life has not shown itself to be a factor with HR cam profiles using SR needle type lifters unless for some reason SR spring pressures are used."
I have a few buddies who have run hydraulic roller profiles with Crower 66260 solid roller lifters with no issues.
Example, one with Dave Bisschop's Old Faithful cam and the other with his Roadpaver cam. One local fellow drove his car weekly for years.
I remember years ago I asked my Comp Cams rep we worked with at the time about it. He told me a minimum of 150 lbs seat pressure AFTER run in.
This was with the Old Fathful cam. I know others have run much more pressure.
( Information provided in this post does not represent any endorsement. And unless specified it is not based on personal experience and is offered for general interest only )
Old 07-22-2026, 12:40 PM
Take this information with a grain of salt ! And further, this should be in the street section.
But like the above post another tid bit here for conversation.....
Years ago during a conversation with a Crower rep I mentioned that my car at the time was street driven only, typically weekends on occasions, and it often sat in the garage not driven.
This conversation was after I had bushed lifter failure. I mentioned our routine of monitoring spring pressure using a on the head valve spring tester and checking the valve lash.
We found no indication of issues with either.
Nothing was resolved as to why and not claiming this was the reason for the failure, but he did point out the following to me.
And with this in mind he suggested I go back to a needle bearing lifter for my particular application.
From the internet, not a quotation from Crower....
"Unlike needle bearings, which rely on tight clearances to naturally trap oil, bushing-style (bushed) lifters feature a larger surface-to-surface clearance that allows oil to drain out when the engine sits unused for extended periods"
