Old 07-19-2026, 02:00 PM
steve25 steve25 is online now
Default The fixes for the big and smaller problems of early Edelbrock chambers
I meant to post this info a good while ago and I just got my iPad going again to get at these photos off it.
The early Edelbrock chambers have a major machining issue in that when the corners of the chambers get machined by two different cutters they, number 1 leave a bad recessed area ( fuel collection pocket)
and 2) leave very sharp edges that make for local hot spots.
These two recessed areas collect fuel that does not light off when the spark lights off the main pocket of air and fuel mixture in the chamber.
These two pockets of unburned fuel either get sent out the exh as wasted fuel, or worse yet (when the temperature gets hot enough to do such ) finally light off late in the burn of the main pocket and then these two colliding flame fronts create a power loss and destruction as in detonation.
In my seperate photos of the stock chamber in these two locations you will see that these two
Pockets I have colored up in black marker .
You can also see the sharp machining edges left also.
There is a particularly bad lip left on the corner of the intake valve that stands up close to .050” and very close to the edge of the valve
There are other restriction and sharp edges around both valves on the shallow side of the chamber that I will make a separate post about.
Mean while grinding and then polishing out these areas on the plug side of the chamber takes the use of some special cutters and a good portion of the material removal and polishing can only be done with the nose of a lot of tapered sanding rolls, and of course with sacrificial valves in place .
Although even then a few areas that needed rework of both valves I found I could only get these areas done without having the protective valves in place, and all of this highly tedious work took me near 3 hours to get the 8 chambers done.
One of my photos shows the ruff cutting with no blending polish done yet.
I hope these photos work well with my info above here, but for certain these two dimensional photos do not show the severity of these two fuel collection pockets left as Edelbrock shipped these stock.
ID:	673665   Click image for larger version
ID:	673666   Click image for larger version
ID:	673667   Click image for larger version
Old 07-19-2026, 05:56 PM
Gary H's Avatar
Gary H Gary H is offline
Great information! Thanks for sharing. One question. When you say early chambers, are you saying all heads before the "heart" shaped chamber?
Old 07-19-2026, 08:28 PM
Yes, although I don’t recall the 72 Chambers being quite as bad as this larger CC one .
Old 07-20-2026, 10:29 PM
694.1 694.1 is offline
Wow. Kinda surprised they even shipped those, much less someone accepted them.
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 07-21-2026, 07:51 AM
PAUL K's Avatar
PAUL K PAUL K is offline
The early 87cc chambers were a mess. Once fixed they worked
Go fast, see Elvis!
Old 07-21-2026, 09:35 AM
tempest1964's Avatar
Great information. I had no idea. Thanks!
1964 Tempest Custom
421 SD clone
KRE 74cc heads
KRE 230°/236° hydraulic roller cam
Rebuilt 3.23 rear end
Old 07-21-2026, 08:58 PM
RocktimusPryme's Avatar
So here is a picture of the #8 chamber on mine when I had to have it out because it ate my carb stud.
Mine doesn’t look nearly as bad as picture 1. Is it just a matter of variation in castings and mine was better?
There is the possibility mine was cleaned up. I bought them used and then they had a small amount of port work done to get them to flow about 305cfm.
Old 07-22-2026, 07:36 AM
I still see the problems I posted about in your heads and the area around the intake valve at 1 o’clock that’s got the carbon on it is a prime area to be unshrouded to the head gasket line .
You can see the difference in one of my photos.
This mod increases the chamber volume by 3.5 to 4 CCs so that needs to be considered.
Old 07-22-2026, 09:40 AM
mgarblik mgarblik is offline
Having a used head with the carbon deposits is great. Joe Mondello taught me in class, " the engine, (cylinder head) will tell you what it wants. It leaves finger prints behind". Steve points out where improvements can be made to help out the bathtub chamber. He has had his hands on so many heads, he knows right where to go and massage. I don't think these Pontiac E-heads are terrible. There are way worse set-ups out there in the muscle car world. 409 Chevy jumps right to the front of the list after struggling with those last year.
Old 07-22-2026, 11:26 AM
I still see it too, I’m just saying it doesn’t seem as bad on mine. Maybe the carbon is hiding it a little.
Mine does like a ping a little in hot weather when pulling away from stops. I could see there being hotspots in there. But so does my 2017 Ram. So did my LS2 C6. So I just don’t worry overly much about low speed pinging like I would at WOT.
If they are out again I want to have them more hardcore ported anyway. While I can def see how you improved it I don’t think I would hurry up and pull my heads off to have that ground down. It’s super cool though to know for the future.
Old Yesterday, 07:04 AM
EHTTFMF was hype?
Old Yesterday, 08:33 AM
PAUL K's Avatar
Originally Posted by Half-Inch Stud View Post
EHTTFMF was hype?
Like hell
Go fast, see Elvis!
