I recently purchased from summit. They advertised a power top/ 6way relay to plug in to the top switch with some modifications to existing wiring. I cant figure out how its suppose to work. Anyone have any suggestions on how to wire it in?
I think you need two of them to make it operate the top. I think I should have just bought the relays with pigtails and put my own packard plugs on. |
Can you post a picture of it?
1966 Strato Chief 427 4 Speed 45,000 miles 1966 Grande Parisienne 396 4 Speed Factory Air (1 of 23) |
Photos attached.
Gray and yellow are spliced together and purple and green spliced together. |
Sorry, I should also have asked if you have a picture of the original relay you are wanting to replace.
No relay existed. 66 2+2 power top switch sent power through the switch to the pump. Over time it burns up the switch. Installing relay to carry the load. Switch just triggers the relay.
Ok, that helps. I'll see if I can find a drawing for you online tomorrow and if not I'll draw one.
Yes, you need 2 relays. One for "UP" and one for "DOWN"
Thanks. The unit I purchased was billed as it would work with a few wiring mods. I thought this unit would take the place of two separate relays. I have a wiring diagram for two relays and have a couple on the way..
I had forgotten about this, I'm sorry.
If you don't get it working with what you have on the way, I can still work on this for you.
While I think of it, can you tell me what color the wires are coming out of your power top switch?
The black wire goes to the block on the firewall in the engine compartment. I did not find a splice in that wire. The green and red to the packard plug to the pump. So a factory switch had a long black wire with a ring terminal and the the red and green were shorter with a packard plug.
Ok, so black will be the power from the horn relay. Red and green will be up and down. (I"m not sure which is which).
We have a bit of a health situation in our family but I'll try to get to this for you in the next couple of days.
