Great game I'll play ...
Edelbrock Torker = 17 Lbs |
1966 389 4-bbl Carter (#9782896 - E 5 6) = 38 Lbs
1967 400 (#9790140 - L 28 7) = 37 Lbs
1967 400 (#9790140 - J 06 7) = 40 Lbs
i have a 1969/70 intake & it weighed 40lb, when it came back from SD doing their max cnc plenum & port package it weighed 36 maybe 36.5. so they ported out almost 4 lbs of metal!
The 72 musta been 41 lbs then, not 31...that's what you get for working in the garage at midnight...
got any pics of that SD prepped intake?
color me gone |
Both weighed on a digital scale we use at work for UPS and FedEx shipping.
Edelbrock Torker I - 15 pounds. 1976 4-barrel Q-jet - 43 pounds.
Edelbrock RPM = 18,3 Lbs
1977 400 egr (#525355) = *38 Lbs *(With the plenum welded and modified to resemble Cliff's/SD's Q-jet intake and with removed water crossover)
1960 Bonneville 2dr HT 389/400ci 363hp 1965 Bonneville 2dr HT 455/501ci stroker 600hp+ |
sadly not any good ones. i got pics of every other aspect of the car/engine build but no detailed pics of the inatke. i think there was a thread recently with some good pics of SD's intake porting work.
Interesting that you have two supposedly identical, same year intakes with a 3 lb weight difference.
Any obvious differences that you can see between the two that's not apparent in the photos? |
Given date codes and casting numbers, shouldn't this one and the other be 1968 versions?
1971 Pontiac Trans Am Cameo White 1968 Firebird 400 coupe, Verdoro Green w/black vinyl top 1968 Firebird 400 convertible, Verdoro Green w/black top 1970 Buick Skylark Custom convertible(driver) Fire Red 1972 Buick GS 455 Stage 1 Royal Blue |
Torker 2 FI with rails
17 pounds
RPM
17 pounds
1971 HO w/o crossover
13.5 pounds
1971 HO w/ crossover&shields
21 pounds
GMPP LS3 Dual plane
19 pounds
#38
Super Victor FI 4500 with & w/o rails
20 pounds
18 pounds (No rails or hardware) |
#39
Came up with 13.93 pounds for a ported Victor EFI 4500 manifold less water crossover.
Thread Tools | |
Display Modes | |
