#141
Tom,
I agree- it's not anything new, just not done that much because most people building Pontiacs want to build 400's, 455's and 461's. I built a 326 with KRE's for probably similar reasons you are building that 301 stroker- because no one else has (at least not that I've heard of). I also like the idea of making hp with less cubes, but still getting some of that abundant torque Pontiacs are known for. Geno |
#142
Block back?
#143
Yes,atJoes,in line for build
#144
The crank is now fit in the block.Will be going to Joes to get pics.The block will then go out for boring etc.When it get back pistons and rods will be ordered.Tom
#145
I can hardly wait!
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#146
Went to Joes this morning,called Nunzi from his place to be sure we were on the right track.Will post a few bad pics of the area that had to be ground to fit the 326 into the block.Also the 400 thrust bearing fit in the block showing the space where the bearing shim will go.Joe has not split the shim yet.The block is going to the machine shop now to be bored and squared.Cam bearings and freeze plugs.Tom
#147
Thanks for the up-date Tom, can't wait to see this thing together and running with some numbers and video---------- I hope I don't ask to much :>)
#148
Looks good, Tom.
#149
Tom, what will have to be done to hold the shim in place?
1970 Lemans Sport, PPR 383/4spd. |
#150
This build has my wheels turning also... Question, doesn't the 326 crank have 3.0" mains? Doesn't the 301 crank use 2.50" mains, so the 301 block main bores should be 2.688-2.689? How can you fit a 326 crank in your 301 block without either grinding the crank 0.5" or opening the 301 main bores to 3" ( 3.188-3.189)? My appologies if I missed something. Thanks, Bryan |
#151
301 blocks are 3in mains.The 303 RA V short deck block is 2 1/2.Tom
#152
The top shim fits in a grove and cant move.Nunzi said to glue the lower one to the block.He said dont worry about it,he has done it a lot.Tom
#153
P-Dude, you need to correct your "Crank ID Chart". https://sites.google.com/site/ksmsin...identification Thanks, Bryan |
#154
block has been bored and pistons ordered!Baby steps.Tom
#155
Hey Tom. If I missed it, what was your final bore size and did you sonic it to see what thicknesses you see? I've heard so many different things about the Turbo 301's having thick and thin walls. Glad you're doing this, except now the price on 301 turbo blocks will likely go up, LOL. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
#156
Mark,we did not sonic,not sure what we ended up with.They were just doing the min necessary.Joe was not concerned as the wall where you could see looked thick.I believe where the concern is with the main webs.I did a short fill and Putin solid main dowels.Trying to do as cheap as possible and see how it goes.Tom
#157
Just a note on the intake fabrication. We looked at the 301T block idea for a sprint boat engine a while back
Intake of choice was a Victor and we intended to section it through the plenum (end to end) to remove the additional "height". Didnt get as far as deciding on a 4500 or 4150 flange but initally it looks like the 4500 would have got the nod Its a pretty common way to do it on SBC here when running their "short deck blocks (very Short !!!) The advantage they see in doing it this way is porting access when its split, plenum is easier to access / weld grind than 8 indivual ports to flange junction, transition work at the plenum / runner entry was probably going to be done anyway. (and easier to hide the modification ) The Victor Pontiac would also alloe for the runners to be shortned or reshaped in the plenum which isnt a bad thing Just wondering if this way wouldhave worked well with the intake used in this thread ??
Working on going faster (and now staying dry at the same time !!) |
#158
You really need to address Dave as he picked the intake and the way to do as cheap as possible.This was always a street build and to try and keep the expense down.The plan was to build a 383 CI 425ish HP pump gas(91)drivable in summer bumper to bumper traffic.The cam is actually more than Joe thought we needed,flo was more than we needed but the cam was in my drawer from a earller build and Dave did not have a CNC program les than 260 CFM.Tom
#159
Bore ended up 4.035.Tom
#160
Sooo, any new updates?
Thread Tools | |
Display Modes | |
