Old 09-10-2002, 11:20 AM
ta406pont ta406pont is offline
Hey guy's I could use a couple of ideas here I want to convert my 79 from power to manual steering and I wanted to know what is involved in this type of project,like what do I need for a steering box,pitman arm etc...
Thanks alot for any tips
Rob..
Rob..
Old 09-10-2002, 12:34 PM
PLAY400's Avatar
PLAY400 PLAY400 is offline
Don't know if this helps but I used a standard steering box and pitman arm from a S10 in my 88 Bird. Was a 5 minute bolt in.
Old 09-10-2002, 04:29 PM
Brian Baker's Avatar
I used a manual box from a 1990 Sonoma (same as an S-10) and reused the pitman arm from my '79 T/A. The Sonoma arm had the wrong angle to it and the bearing end was too small to fit the center link. Pretty straightforward bolt in.
Old 09-10-2002, 04:31 PM
I know someone else that used a box from an '85 S-10 and when I got mine, that was what I asked for, so at least the '85-'90 S-10 and Sonoma boxes are the same.
Old 09-10-2002, 07:19 PM
[img]smile.gif[/img] Cool thanks for the tip I guess I'll have to get a S-10 manual box asap....
Later Rob....
Old 09-11-2002, 03:56 AM
hoffman7476 hoffman7476 is offline
Are you guys building road racers or mostly drag racers or what? I guess you save a lot of weight by ditching the PS...
http://motorhead.iwarp.com
"Not gonna happen, Slim the Slender Gender Bender." The Book of Misus. Chapter 4, verse 18
Old 09-11-2002, 07:50 AM
My TA is pretty much a drag car,but occasionally driven to cruises and such..
Old 09-13-2002, 01:03 AM
Lemans1 Lemans1 is offline
What is the lock-to-lock on those S-10 boxes??
"Artificial intelligence is no match for natural stupidity."
Old 09-13-2002, 05:53 PM
Lock to lock? Not sure, but it's alot slower than a P/S box, and that's what is preferred on a drag car. May not have any lock-lock at all, may just have a worm gear and a spherical gear and be able to rotate 360 in either direction, at which point the lock-lock would be dictated by the stops on the lower control arms.
Thread Tools
Display Modes
