Old 04-21-2005, 10:56 AM
70machone 70machone is offline
I am having problems with my tranny shaking in 3rd gear only. Drive shaft/u joints are ok, torque converter is snug, flex plate was replaced 6 months ago....I have 2 extra transmissions laying around. How do I tell the difference between a 350 and 400. Which is better? Looking for advice/opinions. Thanks in advance, Ron
Old 04-21-2005, 12:56 PM
robg8r's Avatar
robg8r robg8r is offline
I believe it's a 3 speed that was used behind 6 cylinder engines (someone correct me here). It may not be your best bet for towing or for anything with any power.
Old 04-21-2005, 12:00 PM
A friend of mine just said I could have his tranny. I went and looked at it. It came out of his 76 El Camino. By your chart it is the TH200 Metric 11 bolt. It is to go in my 66 pickup truck. Is that a 3 speed? Is it a decent tranny for general purposes ect. Does it have any draw backs or weak points?
Ron
Old 04-21-2005, 10:27 PM
BigDan3131 BigDan3131 is offline
It is a weak tranny, TH350 or 400 would be a better choice unless you want to spend alot more for overdrive.My TH350 will handle 700HP but thats with the best parts.The TH400 is stronger but,you loose 22% or so of your power to drive it.
Old 04-21-2005, 11:54 AM
Thanks a million, that gives me a great reference when going to the boneyard!
Ron
Old 04-21-2005, 11:32 AM
robg8r's Avatar
Pans are different
1 Aluminum Powerglide 14 bolts
2 TH200 Metric 11 bolts
3 TH350 13 bolts
4 TH400 13 bolts
5 TH200-4R 16 bolts
6 TH700-R4, 4L60, 4L60E 16 bolts
7 4L80E 17 bolts
Thread Tools
Display Modes
