1982-92 TA & FB TECH 1993-2002 TA & FB Tech is now part of the new Late Model Section of the PY Forums. Click this link to check it out. |
How much carb to hood clearance is there on a stock 403 manifold? I have a Performer RPM and a stock iron intake but not sure if the RPM will fit. PAW catalog says no but not sure what that means, I could mill the carb flange and use a drop base air cleaner and short element but maybe I'm SOL.
Hi,
The RPM will NOT fit. You can use the kit from www.blockersperformance.com to provide the clearance. I am running a performer on my olds in my 79 TA and its fits w/o any mods. If you are set on running the RPM, bolt the shaker to the hood. olds...... |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by olds:
Hi, The RPM will NOT fit. You can use the kit from http://www.blockersperformance.com to provide the clearance. I am running a performer on my olds in my 79 TA and its fits w/o any mods. If you are set on running the RPM, bolt the shaker to the hood. olds......<HR></BLOCKQUOTE>I'm also running and Edelbrock performer on my 79 ta, you'll need a quadrajet equivilent carb and it will fit without any mods, Edelbrock has carb for that application also.Can post engine photo if desired.The Birdsnest. |
Definitely would like to see a shot of the intake and carb, the Performer clearance will give a good idea of the the RPM fit as I have the dimensions of both. Hood is a Formula, no shaker. Supposedly there is a 2" diff in the manifold heights, so it's going to be a tight fit. I can mill the carb flange maybe 1/2", and use a short element and K&N top so if you guys have an inch to spare I might get it to fit.
Stu,
I can send you some pix under my hood of my 79 TA 403 with performer and Qjet. Need to know where to send them... olds |
Only 2 digital pics I have, hopefully I figured out how to send it, from the Birdsnest.Well I tried but don't know how to post on this forum without e-mail attachment, not familiar with how all this system works.
[This message was edited by BIRDSNEST on January 14, 2003 at 09:55 PM.] |
My email is stuart.sanders@sonyericsson.com
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by stu:
My email is stuart.sanders@sonyericsson.com<HR></BLOCKQUOTE> Hope you got the pics ok Stu, Dave @ Birdsnest. |
Thread Tools | |
Display Modes | |
