Old 09-26-2008, 06:22 PM
78T/A462 78T/A462 is offline
Default motor mount removal
I picked up a 81 nascar edition transam that had a sbc in it before. Im gonna be installing a 400 with 6x heads and bought new motor mounts and need to change them cause the old ones are worn. Ive owned my share of 2nd gen transams but ive never changed the mounts before and the look almost impossible to get to. The passenger side looks like the frame has a hole where I can get a boxed end wrench on the nut but the drivers side doesnt have the same hole in the frame. Any trick or advice to getting the bolts and nuts out?? Should I remove the A arm?? Thanks for the help and sorry for the newbie question.
Alvin
Old 09-27-2008, 07:34 AM
dean7276's Avatar
dean7276 dean7276 is offline
Just replaced mine a few months ago,the control arms were installed but it would have been much easier if they were off.There should be a small hole to access the bolts with a box wrench.I was scratchin my head too at first, but there was a way to get to these bolts.
Good luck.
Brakes? Who needs brakes,they'll just slow you down!!
Old 09-27-2008, 06:10 PM
Thanks for responding Dean, im about to tackle it right now!
Old 09-28-2008, 12:23 AM
72 Street Bird's Avatar
72 Street Bird 72 Street Bird is offline
When putting the nuts back in use a small scrap of paper folded over as needed. Put the paper over the open end of the wrench and push the nut down into the wrench. The paper will hold the nut in place until the bolt is tight and you can pull the wrench out without having the nut stuck in the box end.
72 Firebird, sorta green, mostly gray with a red trunk lid.
14.9 @ 95mph in the Quarter mile. Street tires, highway gear open rearend.
PRO Series True Street 15 second index winner 2003, 2004 Cordova, Il.
Old 09-28-2008, 07:28 AM
dean7276's Avatar
78T/A462, how did you make out?were you able to get them?
Old 09-29-2008, 09:41 AM
Grand73Am Grand73Am is offline
And I guess you know you need to be using pontiac engine brackets from a firebird/ta only on your engine....
Old 10-06-2008, 12:12 PM
2manyT/A'S's Avatar
I took an (import) 9/16 combination wrench & bent the box end at a 90 degree angle.
Used some duct tape to hold the nut in the wrench for re-install & it sure made MY job easier.
Old 10-14-2008, 12:32 PM
Its been kind of hard locating pontiac parts for the car since it had a sbc in it before. I think I have all the parts now and should be doing the deed tonight hopefully.
Old 10-14-2008, 07:43 PM
Darren.D's Avatar
Darren.D Darren.D is offline
I just changed mine also. I looked in the shop manual which shows the bolts coming up from under the frame. There are some holes under so i just used a socket and long extentions to hold the bolts. Found it fairly easy.
Thread Tools
Display Modes
