just wondering if anyone has seen this conversion done. This concept is stolen from a longtime Pontiac friend of mine who has several of these setups running with thousands of miles street and track. I am putting this one together for my test mule engine has a comp 276hr cam. I am working through what all lifters will work without oil band issues. The spider hold downs are not what will be in this engine they are just to hold them in place for mock up and finessing.
what spider ws used
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
Interesting idea, didn't the later olds 307's use roller lifters which should be at least close to the pontiac oil band location?
According to Rockauto, they are 0.921" Ø
Engine Valve Lifter Material Steel Maximum Outside Diameter .921 in. Lifter Type Hydraulic Roller Yes Alternate/OEM Part Number(s): 05740043, 3C3Z6500AA, 5233645, 5234295, 5234435, 5234470, 5234530, 5234625, 5234680, 5234755, E3TZ6500A |
spider is small block ford with some tweaking. Dog bones are also sbf with some mods to the bottom to clear the block radius. Lifters are a gm factory roller lifter for a 60 degree v6. There are also some gm v8 lifters that will work. Im working on some other lifters now waiting on them to get here to verify dimensions.
| The Following User Says Thank You to 68hotbird For This Useful Post: | ||
I've been thinking about trying something like this. Thanks for sharing
Didn't the Olds diesel have hydraulic roller lifters ?
Maybe a natural fit there. A long time ago saw one in a junk yard apart but that was a long time ago and maybe iam recalling incorrectly
........... The More You Follow The Herd The Less You Can Be In The Lead .......... |
We had a warranty diesel engine core in the buick service department that I was working at. I was going to remove the roller lifter from to try them in one of my Pontiacs, As soon as I removed one it was obvious that they were much larger diameter than the gas engine lifters are. |
| The Following User Says Thank You to Sirrotica For This Useful Post: | ||
The spiders could be made exact fits slicing and dicing and tig welding the pieces back together. |
Question, Maybe I'm missing it, but how will you now bolt the valley pan down if the threaded holes for those bolts are now used for the spider?
I was thinking about that too, the op said it was a temporary setup for mock up but i think you could just use studs and nuts to get it done.
enough, as long as they don't touch the cam bearing. Maybe a little Loctite, just because. |
I built solid roller lifters for the hemi V8 starting with early SBF HR lifters. I made press-in sleeves with cups to match the hemi pushrod angles. The anti-rotation guides aren't pretty, but they work well.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926}
| The Following User Says Thank You to Jack Gifford For This Useful Post: | ||
Sam
-- Sam Agnew Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it. Ministry - Jesus Built My Hotrod |
Securing the spider, A quality all thread ABOUT 5-6 inch length, thread it into the block drop the spider over it run a lock nut down then install the pushrod cover with flanged nuts dab some silicone around the nuts
........... The More You Follow The Herd The Less You Can Be In The Lead .......... Last edited by Formulas; 02-02-2020 at 08:02 AM. |
What is the rest of the combo?
I've done this with early small block fords because the new spider and dog bone parts interchange without modification, and it saved quite a bit of money over the retro rollers for the early Fords. Here's a 69 351 Windsor I converted to roller with factory Ford parts. Spider and dog bone is only $55 from Ford Performance, and the lifters are only $120. What I thought was cool was that the block is 50 years old and no mods necessary, the newer parts fell right in. Yet they still sell retro rollers for these things. |
Might be dumb ?, but I'm a flat tapett man, never messed with a roller. Does this lower the cost of going to a roller?
Best so far 1/8 et,8.90 on street tires, Since that I have added 400 heads. I call it a rat sleeper. |
The valley cover will be mounted with studs that will hold down the spider also. I am fabricating a rectangle washer to put below the locknut to help make sure the spider doesn't twist. I will post more pics once the final assembly is done. Hope to get it finished up and running soon. will keep everyone posted and also update as I check the other lifters for compatibility.
| The Following 2 Users Say Thank You to 68hotbird For This Useful Post: | ||
| Thread Tools | |
| Display Modes | |
