Can the bushing that the oil filter screws on to be removed ,any suggestions?Is screwed in or pressed in place? thanks joe
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119 |
Not on a factory oil filter bracket that I am aware of!
I do stuff for reasons. |
Factory oil filter housing I believe has the "part with the threads on it" cast into the casting to retain it.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post: | ||
Replacement are thick on the ground, need one?
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
So it can be unthreaded from the housing?I would like to remove bushing and replace it with an 1/2 " bushing for use of a Wix 3 micron .Ive modified the stock housing with a blockoff plate with required unions for external use.
![]() Quote:
If you want a better job of removing dirt from the oil you need to make 2 specific circuits for the oil. One circuit is the full flow filter plumbed just the way it was OEM, and one circuit taps off the pressurized oil and goes through the 3 micron filter, then returns back to the pan. You can never get enough volume through a 3 micron filter to supply the needs of a running engine. Below is a diagram of how the 2 circuits are plumbed using the OEM pump to supply both filters: ![]() Your by pass filter is capable of filtering 5 quarts in 5 minutes, not nearly enough to supply the wear surfaces of an engine, but plenty fast enough to filter the oil to a very high standard every 5 minutes. You also need a restrictor on the by pass portion of the system, usually .125, or 1/8 inches. Some filters have a restrictor built in, others need a plug with a hole in the pressure side of the system. Hopefully I have explained it well enough to give you the basics of a safe setup.
Brad Yost 1973 T/A (SOLD) 2005 GTO 1984 Grand Prix 100% Pontiacs in my driveway!!! What's in your driveway? If you don't take some of the RACETRACK home with you, Ya got cheated ![]() ![]() ![]() ![]() Last edited by Sirrotica; 02-09-2022 at 08:34 PM. |
The Following 4 Users Say Thank You to Sirrotica For This Useful Post: | ||
Sirrotica who in the hell said it was a full flow?
I want to swap out the 13/16 bushing for a 13/16 to 1/2" adapter bushing to use my modified stock oil adapter with an -8 unions that will be externally located with wix 3 micron filter.So simple ? Can the stock 13/16 threaded bushing be unscrewed from the stock housing?
![]() Quote:
Stop and think about it. You want to screw a different filter on a Pontiac adapter maybe I didn't read close enough, but it sounded like you wanted to replace the OEM filter with a 3 micron. I'm just trying to help you out, and buying the remote mount is the easiest way to get where you want to go. $28 bucks will get you what you want. https://www.speedwaymotors.com/Singl...RoC4TkQAvD_BwE |
The Following 2 Users Say Thank You to Sirrotica For This Useful Post: | ||
I'm pretty sure the housing is all one machined unit.
The Following User Says Thank You to hobbygto65 For This Useful Post: | ||
Will even the oil filter sealing pad on the stock housing be in the needed place to seal that Wix filter up?
![]() Wow, The guy is just trying to help you. Maybe a Thank you to him for taking the time out of his life to offer advise.. Just saying. ![]()
The Following 4 Users Say Thank You to chuckies76ta For This Useful Post: | ||
Sirrotica ,All the remote setups have the lines coming out the sides in relation to the mounting pad.I like my setup better.I have it mounted under front fender with very limited space.oh bypass is blocked off,just in case someone wants to ask.Charles 12 post and still no one can answer the question (is the stock threaded bushing, the filter screws on to, be removed from housing?So who is wasting whos time?
Should that factory threaded bushing be removable just what is your plan to get what you need in there?
![]() Quote:
I just looked at a oil filter housing. Too me it looks pressed in. The threaded nipple that holes the oil filter is steel and the housing is Aluminum. Without actually wrecking a housing would be the only way to know for sure how the steel nipple is installed. It looks like the Kauffman housing is all Aluminum.
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 02-10-2022 at 01:46 PM. |
Sometimes you get an idea/question that is only answerable one way:
Get an old oil filter housing and cut it in half so you can see for yourself. Or just run over to the hardware store and buy a pipe nipple for your fabrication. Seems easy enough. You've gotten a dozen responses without an answer you like - maybe it isn't such a good idea? Good luck! |
The Following User Says Thank You to Joe's Garage For This Useful Post: | ||
Now that we are back on track,Ide like to replace that bushing (nipple) with a 13/16 to 1/2 adapter nipple so my baldwin 3 mic will screw on.Don't people read post be responding anymore
You can buy by pass filters with 13/16 inch thread.
If you want a remote base where the lines come in from the top, with a 1/2 inch pipe thread, here it is: https://www.summitracing.com/parts/p...waAggxEALw_wcB The answer was given already, the steel insert is molded into the aluminum housing, post #3. If it were threaded into the housing it would have an internal hex, or 4 sided internal drive recess, to tighten it into the housing. As the conversation goes on, pertinent facts that weren't given in the initial question have been brought to light. I don't believe one here was trying to waste anyone's time, but telling the whole story up front would have been helpful. |
The Following User Says Thank You to Sirrotica For This Useful Post: | ||
Here’s a suggestion.
Why don’t you use a cut off disc to cut back that original filter nipple as short as you can. You can even ware down a cut off disc to a smaller OD to get in even closer and cut the nipple shorter. I do this to get cut off disc into tight places by cutting into stone or a brick. The original nipple is .8125” in OD. The needed drill bit to tap a hole for 1/2” pipe is .9062” in OD. It will take a drill press for sure, but you could drill and tap the Housings original bushing and then just thread in and red Loctite the 1/2” you need.
The whole idear behind the post was to keep from tearing a housing apart.I figured alum housing with steel nipple It has to come out someway.Tom was the closest right off the bat,but I was hoping for hands on experiences.Next time I ask for something I will start my post with To whom who has hands on knowledge of such and such
Thread Tools | |
Display Modes | |
