One for the experts on a fiber optic cable
I have an 80 pace car Trans Am
I pulled the dash cluster to replace the clock with a turbo boost gauge from TTA Performance. By the way (Joe) one of the most knowledgeable on the Turbo TA out there. There is a fiberoptic small cable / that has a small metal z clip attached / that plugs into the back of the cluster but I can't remember where it plugs in to. The cable length is not that long so it is limited as to where it goes. I put in a small hole, on the right facing the cluster installed with an existing twist bulb socket holding the z bracket in place Any help would be greatly appreciated I can send a picture if this would help THANKS AGAIN |
top of the ash tray .housing ... ??
Scott is correct. Top of the ashtray
1977 Trans Am 400/4speed (swap) Brian |
Yep top of ashtray.
Thank you to all 3 people
Thank you
Does someone have a pic of how it exactly sits in there Thank You Again |
Thanks for the picture would be very hard to find
Thanks Again |
The headlight switch also uses a fibre optic cable
^^^^ it does????...where
The Following User Says Thank You to 78w72 For This Useful Post: | ||
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
im aware of that... but it wasnt for the headlight switch, the plastic prism is to illuminate the wiper/washer on the bezel, although it does mount to the H/L switch.
both.....
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 Last edited by 77 Canamman; 02-20-2022 at 11:27 AM. |
Correct the plastic, it’s been a while
The Following User Says Thank You to rock For This Useful Post: | ||
Thread Tools | |
Display Modes | |
