Cam degree drama
I'm a virgin cam degree'er so be kind.
I'm swapping my heads/cam/intake over to a different block. My local machine shop put my previous setup together years ago. I wanted to verify the cam was installed correctly, so a few youtubes later I'm an expert right? Cam is a the stump puller on a 114LSA. ICL at 109. Here is my post on FB for some picture. https://www.facebook.com/groups/1612...omment_mention My local shop wrote their numbers down on the cam card when they degreed the cam. 150 and 70 = 220 / 110 deg. I had the heads on and was using a piston stop. I cam up with the same 150 but 73 for my other, thus my number came up to 111.5 deg. Using the intake centerline method taking measurement in the clockwise rotation. The timing chain does have a small amount of slack. On the cam card the local shop wrote "crank 4deg Ret". That is correct that was how it came off the old motor and went back on the new to me motor. So 2 questions and this is really bothering me. 1. On the cam card the engine builder also wrote "Cam key 11+ Advanced" What the heck does this mean? How is it relevant to degreeing the cam? Is it maybe referring to an offset key on the cam? I didn't see one, but wasn't looking either. Maybe referring to ground in advance? That would be 109-114 that would 5 deg. IDK. 2.. I'm tempted to tear back into it and change the crank sprocket to strait up and remeasure. IS the +4/-4 on the crank sprocket equal to what I should see at the lifter? Meaning if I was at 111.5 and move to the strait up mark should I be at 107.5? That too much? I found this in the Archives. Not sure where my 114 LSA falls into this discussion. https://forums.maxperformanceinc.com...ght=degree+cam Thanks for any help. |
I have found that variations in measurements when degreeing a camshaft is primarily caused by the dial indicator not being "square" or " parallel " with the valve, or not having a flat surface to place the dial indicator stem tip on the valve retainer. Those two items can cause issues trying to get an accurate, repeatable measurement. Regarding the +4. Most cam manufacturers are adding 4 degrees advance in when grinding the cam. It will generally say that on the cam card by stating the cam grind number followed by +4. Lastly, if you use the +4 keyway and marks on the timing gear, it should advance the cam 4 degrees. Naturally, it needs to be verified by degreeing the camshaft in.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The Following User Says Thank You to Gary H For This Useful Post: | ||
I use a lifter that comes with a degree kit set up which helps a bunch.
As noted in the above the dial indicator must be set up perpendicular in both planes. The lifter needs to be lubed with a very light oil, such that almost no pressure from the dial indicator is needed to have it follow the cam lobe with total accuracy on the closing side .
I do stuff for reasons. |
The Following User Says Thank You to 25stevem For This Useful Post: | ||
Did the FB link work? There is a picture of the cam card there. I see that there is a Part# and a Serial# The serial number: v 9054-11. Maybe that -11 is where they got the 11 deg Advanced? Regardless do I even car about that number? I'm still trying to hit the 109 ICL correct? And advance or retard is from that reference. |
I'm concerned I'm leaving a fair amount of lower RPM power on the table at the 4 deg ret crank sprocket setting. I never felt it had the low end grunt to live up to the stump puller name. Above 3500 it pulls hard though. Reading that other post I linked seems to make sense to change the crank sprocket to strait up. |
Great tool. Eliminates some potential variables which is always a good thing.
https://www.summitracing.com/parts/p...38?seid=srese2 |
To just reinforce what’s mentioned in post 2 here, many cams are made with 4 degrees of advance ground in to cover for normal and eventual chain stretch.
PS: no worries you did a good job on degree it in.
I would tend to agree with ya, however I got the same number as the machine shop with 150 closing. The question still remains should I re-set the crank sprocket to 0? The cam is current a few deg ret as measured. Seems like I would be better off a few deg advanced. |
Where are you measuring 150 at?
The cam has a 114 LSA and the cam card wants a 109 ICL Using intake 6 BTDC and 44 ABDC will have you at 109 ICL Stan
Personally I would leave it, right were it is. Usually advancing the Cam picks up bottom end, seat of the pants and a chance of picking up ET, maybe, but top end usually suffers. Show it’s a trial and error thing. But if it’s a nice street cruiser I doubt your going to notice much of a difference. I mean you can try it at zero and see what you end up with.
Most of the factory cams were on a 114 , so cam company’s knew advancing them along with a little more intake and exhaust duration would definitely make more hp. They also knew the heads was the restriction. So basically even though they say 109, they Knew with Timeing chain stretch, it’ll end up at 111-112. What their banking on is the opening and closing…change that to much and it’s going to effect cylinder filling.
Basically followed the same method Fast Monte used as instructed by Buttler. https://www.youtube.com/watch?v=jKpk64KWqag&t=992s Quote:
Well you know your car better then anyone else put in at Zero and see what you come up with, see how much it advances. I’d be interested to see how much.
The only thing those 3 keyway roller chain sets are good for is to practice my hook shot to the trash can over by the shop door. If you are going to run a bicycle chain on the front of your engine at least get one with billet sprockets and 9 keyways so you can accurately move the cam timing around........FWIW.......
The Following User Says Thank You to Cliff R For This Useful Post: | ||
Stan
The Following User Says Thank You to Stan Weiss For This Useful Post: | ||
I think the Intake Opening event is subjective when going by Degree-wheel readings:
ILC from IO to IC gives a Measured result BUT, i think there needs to be a bias on the number so you know the ILC might effectively be an effectively advanced value above the measured value. I always assume non-symmetric lobes. While in there; Try for 2 types of ILCs based on "onset of Opening/closing, and 0.005" lift for ILC. Oh sure 0.050" values could be an3rd basis but not as defining the Idle result as 0.005". Same goes for Exhaust ELC from EO to EC, but sooo less critical. My last Cam Degree activity was fraught with looseness from every possible non-fixturing frustration. And the 14" dia degree wheel in 1* toothed increments magnified my lack of accuracy. I gave up and sold the ( Spare ) engine with explanation of the degree activity. Was easier 40 to 30 years ago, when i was not sweating the precision details. |
The other thing I followed was keeping all measurements in Clockwise rotation. I found this cam timing test of interest to me. They went pretty extreme from -2 to +10. For me my concern would be possible detonation (Ping) issues if I were to go to advanced. https://youtu.be/wimUgFd0Qkg |
"What do you recommend? I thought those 9 key crank sprockets were terribly unreliable."
The Rollmaster 9 keyway set is DEAD NUTS on the money for moving the cam and on the upper end for quality with roller type timing sets. Those 3 keyway sets not so much. They are usually pretty close dot to dot at the "zero" keyway, but after that they can be all over the map for where you end up at from what I've seen here. I've installed a number of Rollmaster sets in customers engines, they seem to be at the top of the pile and marketed by all the big Pontiac shops and used my most Pontiac engine "builders" from what I've seen. For my engines I use the factory 3/4" wide stock Morse timing sets and offset cam keys if I need to move the cam.......
230 / 2 = 115 - 6 = 109 ICL Once the ICL is set so is the ECL so why check it? 236 / 2 = 118 - (-1) = 119 ECL How else can you see what the LSA of your cam is and that it is correct? 109 + 119 = 228 / 2 = 114 LSA Stan
Here I ALWAYS back up the ICL checking by also turning the engine is the same direction and taking a look at the intake open point @ .050". The cam card will also tell you when the intake opens in crankshaft degrees.
So if the cam card (for example) says that the ICL should be 109 and that the intake opens @ .050" at 8 degrees BTDC then it should be very close to that number if you have the ICL in the correct place. I actually prefer to to use the intake open point vs ICL since a LOT less movement of the dial indicator is required. With the ICL method you are going clear up to full lift and recording numbers on both sides of the lobe. It sounds easy when folks talk about it but it can be a real PITA to get your dial indicator set up so it has the correct geometry to record the lobe movements without any errors from slipping or moving on the magnetic base, etc......
Thread Tools | |
Display Modes | |
