Old 04-07-2024, 06:51 PM
FHC1971's Avatar
FHC1971 FHC1971 is offline
Default Deluxe belts for 1971 Firebird
My 1971 Firebird Formula came with Deluxe Belts (AK1) option. The shoulder belts are missing. Does anyone know the model # for Hamill Belts that my car should have had from factory. Also, if it makes a difference, my car came from Van Nuys.
Thanks Frank
Old 04-09-2024, 04:18 AM
Red80TA Red80TA is offline
There's various model and part numbers in the Part Manuals, the 67-75 not as easy to look through as separated volumes and no search option for digital version, mine anyway. The part number on the belt may not always match the part number GM listed either, if you were simply going to search through belts for something that matched. Or it might.
If I get a chance I'll have a look, front shoulder belts, not the rear option.
Old 04-09-2024, 08:51 AM
FHC1971's Avatar
Thanks. Yes front. It might be easier if someone with a 71 Firebird with Deluxe belts just looked at their belts to see what they have. I believe the regular belt made by Irvin is model 2050.
Old 04-09-2024, 09:27 AM
Will look at early '70's seatbelt stock, have parted quite a few '71 Esprits.
The 4 digit model number will be the same between the front female belt & the male shoulder belt. Just went through this on my '72 belts (having tags made). Are you missing the female belt as well as the male shoulder strap?
Old 04-09-2024, 09:48 AM
FHC1971's Avatar
The important end is the male. The female end can be different. Length is very important for the male (shoulder) end. The elastic makes the length critical for the male end.
Old 04-09-2024, 11:57 AM
unruhjonny's Avatar
unruhjonny unruhjonny is online now
interesting discussion;
I don't know anything about "Hamill" or "Irving" (I will have to look into what this is)...
I had understood that the 70-72.5 (male) shoulder belts were all the same parts (belt color not withstanding);
I had understood that the female side was the same part between the lap and shoulder belts - and the variations were black plastic housings (with black belts; standard) and either colored plastic housings (and color matched belts; deluxe) or brushed stainless stainless housings (and color matched belts; deluxe).
I did not know the model number was for the pair;
I have interpreted this as meaning the match pair had corresponding model numbers on the tags.
1970 Formula 400
The Following User Says Thank You to unruhjonny For This Useful Post:
Old 04-10-2024, 07:39 AM
starlightblack's Avatar
starlightblack starlightblack is offline
Hamill and Irvin (not Irving) were the suppliers
ID:	631850   Click image for larger version
"Spend all your time and money on that Pontiac GTO pile" - The Go-Gos, 1981
Old 04-10-2024, 09:12 AM
unruhjonny's Avatar
that makes sense;
iirc my tags are all quite faded.
1970 Formula 400
Old 04-11-2024, 10:24 AM
RAIVJUDGE's Avatar
RAIVJUDGE RAIVJUDGE is offline
Default Shoulder belt pictures
Here’s the tags that are from my low mileage original interior. 71 TA. Shoulder belts had two tags. One close to the point where they are anchored to the roof and the second by the buckle.
ID:	631906   Click image for larger version
Atoll Blue, Blue interior, 1970 RAIV Judge/4 spd/ 3.90/ pwr steering/ pwr brakes/ hoodtach/ gauges/ sport wheel/ console/ remote mirror/tinted glass.
Starlight Black, Camel Tan interior, 1978 Trans Am . Auto/AC/door edge guards/ am/fm, Cassette stereo/ floor mats frt and rear/Hurst Hatches
Cameo White, Blue interior, 1971 Trans Am/4spd/ Am/Fm/ power windows / AC. 28,000 original miles
The Following User Says Thank You to RAIVJUDGE For This Useful Post:
Old 04-24-2024, 03:53 PM
unruhjonny's Avatar
I just dug this up;
I have five-ish of these;
two from my car (pulled from a 1970 Camaro);
two are spares I have, and a fifth... well 1/4 of the fifth - is only the male (roof mount) end, and missing the metal belt end.
The early shoulder belts are fairly easy to identify because of the unique mounting end which should have a snap closed plastic cover.
The two from my car have faded blue tags with no readable printing;
The third one is a fairly nice looking blue tag, but again, unreadable printing;
The fourth is a faded and worn blue tag, but I can read the Irvin model - it matches what RAIVJUDGE showed - 2050, and I think the date might be 7A70.
The fifth one is a white tag, and is almost perfectly readable;
It has a printed GM part number of 9610210
It has a printed Irvin number 2206
It has a printed date of 13A72
1970 Formula 400
Old 04-24-2024, 05:18 PM
The original poster was looking for '71 F-body Deluxe shoulder belts.
Those will be made by Hamill & have their own shaped male end.
I have a complete set of '71 Standard Black F-body belts, they are the same style Irvin belts as posted above by RAIVJudge. Am searching through boxed old stock for any '71 Hamill deluxe belts i kept from previous partscars. Have multiple dozens of original early '70's A-body & early 2nd Gen belts. If a mediocre quality seat belt had a rusted pitted male end or buckle, I cut the anchor end off & often threw away the remainder of that belt.
On the Irvin model 2206 part number 9610210 belt dated 13A62, it is not an original F-body belt. Am 100% sure of that, have put a lot of time into restoring my late '72 T/A's seatbelts & am having tags made for them. Late '72 model F-body front & shoulder belts were Irvin 2212 & have a specific style female buckle & male ends. These did NOT share the exploding style small textured buckles used in '73 F-body's.
Old 04-24-2024, 06:20 PM
unruhjonny's Avatar
thanks for the correction;
I have that 2206 "belt" wrapped up - and it's been some time since I unwrapped it, so it may be the wrong length.
I never took the time to notice these detail because the only belts I bought for my car, are ones that I have a clear memory getting;
I pulled them from a 1970 Camaro;
A car that had me stumped at the time because the emissions sticker said "400" - I knew at the time that the small block 400 was never offered in the Camaro
I later came to realize meant that it was an SS-396 (402) car.
I share this because in my mind, since these shoulder belts came from another 1970 model, they were inarguably correct for my car.
I pulled them from the best wrecker at the time in Winnipeg for F-body parts - and that was in July (or possibly early august) 1995.
... I also have the original jack cover from that Camaro.
I understand those are pretty rare (original) parts these days, and I found it odd to learn that they were never used in Firebirds, rather were a Camaro-only part.
1970 Formula 400
Thread Tools
Display Modes
