Old 11-05-2003, 08:52 AM
68ragtop's Avatar
68ragtop 68ragtop is offline
I have a 1997 grand am that won't start. Cranks, but won't fire. This was an intermitant problem, but now it is dead. Once the car would start, it would run without every quiting. But after it would sit over night, or all day, It would not start. I used my snap on mt2500, & it shows no codes. I do not appear to have any spark, but I am not thinking coil packs, because I thought those usually fail one at a time & cause more of a rough idle? (this is the 3.1 V6)
I can hear the fuel rails prime for two seconds, when I turn on the key. Could this be a crank sensor? Can anyone tell me a good way to test the sensor, or how to test the coils?
I am a little lost on this one.
Thanks, 68ragtop
1968 GTO Convertible (currently my resto project)
1978 Gold Edition Trans am
1979 10th aniversary T/A
1980 Pace Car Trans am
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
68ragtop's Avatar
Thanks, 68ragtop
89 Trans am GTA
Old 11-05-2003, 05:44 PM
gtoguy1967 gtoguy1967 is offline
Crank sensor was my guess? not sure how you check them though?????
Don
some times when you race with squarals you get your nuts cracked!
some times when you race with squirrels you get your nuts cracked!
Old 11-05-2003, 06:45 PM
Oreif's Avatar
Oreif Oreif is offline
This explaines how it works. It can be tested with a regular DMM (volt meter) Just hook up to the signal wire and turn the engine.
http://www.kemparts.com/TechTalk/tt10.asp
Happiness isn't around the corner...
Happiness IS the corner.
1986 Fiero SE
Now ZZ4 Powered!
Old 11-05-2003, 07:06 PM
TIAUTOMAN TIAUTOMAN is offline
Could be a crank sensor, but you should also check for power out of the ing switch.
the starter is obviously getting power if it cranks, but the ing moudul may not be getting power.
also you should check fuel pressure, even though you can hear the pump run doesnt mean you ahve enough.
Old 11-05-2003, 07:08 PM
you also have the ing module, what the coil pack sit on. those can fail, and of course the pcm can always be the problem.
WHAT DOES YOU SCANNER YOU HAVE DO?
will it read real time data?
check the 24x crank signal is there a rpm reading?
Old 06-17-2004, 10:25 PM
Kitt_Collinson Kitt_Collinson is offline
I would actually start at the coil packs.I am sure you dont need me to tell ya that these little boogers can mess up your whole day.You said it progressivily got worse?you might want to consider the crank sensor.It did the same thing on my sisters car.I cant recall if it was the same year or not but it would start hard,run with no problems,sit over night and not want to start the next day.It finally just wouldn't start at all.I took it into the shop for her,shelled out the 80 clams to hook it up to a diagnostic and that was the problem...the crank sensor.
