Old 10-18-2004, 08:33 PM
68droptop's Avatar
68droptop 68droptop is offline
Here is my 68 GTO corner patch that took a while for me to do, but I'm happy with it. Butt welded in. First pic is of the rust.
Project "Thanks Dad!"
68droptop's Avatar
Old 10-18-2004, 08:34 PM
68droptop's Avatar
Second pic.
68droptop's Avatar
Third pic.
Old 10-18-2004, 08:35 PM
68droptop's Avatar
Last one.
Old 10-18-2004, 08:41 PM
md1twal3 md1twal3 is offline
Nice work...my first patch doesn't look so good yet. Stay tuned for a post titled RF fender patch
"My ol' man is a television repairman...he has an ultimate set of tools!....I can fix it..." J. Spicholi
Old 10-19-2004, 02:35 AM
Dave Wanichek's Avatar
Dave Wanichek Dave Wanichek is offline
On Vacation
Good work!!! Looks great!!!
Old 10-19-2004, 02:39 AM
Looks really good. Did you form the patch or did you cut it from a donor?
My '68 has a rust problem in the same area. Several areas in fact but I dread trying to start cutting on my car for fear I'll make things worse.
Old 10-19-2004, 03:12 AM
troy_barker's Avatar
troy_barker troy_barker is offline
Did you weld that from the back side?
How did you get it to look so nice?
Bring back my 67 GTO: Shes ALIVE as of 2-19-13
previously owned
78 Firebird
67 Nova
64 Nova
Old 10-19-2004, 06:08 AM
68droptop's Avatar
Thanks for the replies.
Greg,
It was cut from a donor car. Then I cut and trimmed it to fit. Took a long time.
Troy,
This was welded from the outside. Like I said, it took a long time to cut out and fit. Then I just kept tack welding and grinding until the seam was welded shut. I've been using a thin cut off wheel to grind my welds down. The same one I used to cut out the rust. I don't know if anyone else does this or not, but its the only thing I had to grind with.
Thanks.
Old 10-19-2004, 06:18 AM
Rusty 68 Rusty 68 is offline
I have the same problem on my 68 convertible. I'm looking for that corner piece from a donor car. I need both sides. Does anyone out there have this to spare, or know where I could get it?. Thanks
Old 10-19-2004, 06:37 AM
There are guys in the parts for sale area that will have these. look through some threads or just post asking for the parts...
Old 10-19-2004, 07:08 AM
shawn e.'s Avatar
shawn e. shawn e. is offline
Good Job
"Don't let fatigue make a coward of you."
Old 10-19-2004, 10:53 AM
fyrebird68's Avatar
fyrebird68 fyrebird68 is offline
Nice work! ..
I have the same patch to do on my 68 convert. Judas sent me a nice pre-formed patch that will address most of the problem.
Its on tap for as soon as I put the car down for the winter.
68 GTO ragtop
91 T/A
69 XKE
Old 10-19-2004, 11:50 AM
wlpsyp wlpsyp is offline
Very nice work. I like to see others take on the challenge of these repairs. Keep it up.
Bill
_____________________________
It is not a problem.... It is just a blood pressure monitor.
Old 10-19-2004, 05:54 PM
GDK_1968 GDK_1968 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by 68droptop:
<HR></BLOCKQUOTE>
Visit your local automotive paint and body supply store, pick up the 3M Roloc discs for grinding. Although the cut-off wheel on a die-grinder comes in handly for tight spots I would really recommend the Rolocs for areas like you have done on the corner. With the various grtis available you'll spend less time grinding or worrying about the cut-off wheel gouging your nice work.
Visit the 3M web site or look here for a nice sample of the Roloc line.
Keep in mind there is a special madral required to use the Roloc discs. Chuck that into your die-grinder and you will never go back to a cut-off wheel for grining.
Darryl
1969 GTO Restoration
Old 10-19-2004, 08:30 PM
68droptop's Avatar
GDK_AL,
I have a 3M roloc, but I havn't used it to grind with. I'll have to get some grinding disks and try it. Thanks for the tip.
Great web site. I use it often to look at what you did to the 1/4 panels.
Thanks.
Old 10-20-2004, 01:21 AM
The only reason I asked if you did it from the back is beacuse it did not look like you had a wide enough gap between the 2 pieces to butt weld them.
previously owned
78 Firebird
67 Nova
64 Nova
Old 10-21-2004, 04:30 AM
PetesPonies PetesPonies is offline
A tight fit can work for MIG, howevber, I like about 1/16". It is all about penetration of the weld. If your heat is set right, you will get the penetration needed even if the fit is real close.
Pete's Ponies
Mustang RUSToration & Performance
Old 10-21-2004, 04:06 PM
bad69bird's Avatar
bad69bird bad69bird is offline
Nice job dude, good fab work!!!
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
