Old 09-17-2002, 02:30 PM
Taff Taff is offline
Home ported no.16 d-ports,surface cut by 0.060",stainless tall valves,Ford 7/16" ARP rocker studs.
Old 09-19-2002, 06:05 PM
David Holmberg's Avatar
E-Heads, Ported by Pontiac Dude...
Old 09-22-2002, 10:42 AM
boykoman boykoman is offline
Ive run 9.60s at 139 with a 1.29 short time in the bird no nos just a 462 with steel heads.This is a personel best for me so far and the air is getting colder!!.1/8 mile time was 6.12 and change.Hey Chad if you come up make sure you bring enough head flow.All in fun of course!!!
Old 10-20-2002, 07:07 PM
E-Heads 564 equivalent cfm at 15 psi boost. That
is right about where the good Pro Stock Chevy
heads are right now. (282 at 25 inches with a tootsie roll touch-up. 255 exhaust at 25 inches
with a lot of work.) Marty Palbykin made 1400 hp
with a 240 head at 25 inches. With boost the head
flow is not as important as the sealing and I wanted my intakes/ heads to be as strong as possible. Tom V.
Old 09-18-2002, 04:11 AM
Engo's Avatar
Engo Engo is offline
#62 d-ports. Ported to flow 260/200 cfm.
Performance in a 3800 lbs weight as raced car see below.
Street ´69 Firebird 455
D-ports and drag radials...
[email protected] (motor only)
[email protected] (+180hpNOS)
Street/strip 1969 TA clone. Back halfed. 3300lbs. Twin turbo LSX 387cu. JW glide. Holley Dominator EFI. E85. Street driven.
https://www.facebook.com/photo.php?f...type=1&theater
Old 09-16-2002, 09:46 PM
I have one car that gets raced 100% of its running time. I have another that gets driven to work 99% and bracket raced 1%. Include my driver in your poll? It has won its share of race trophies. [img]/infopop/emoticons/icon_biggrin.gif[/img] [img]/infopop/emoticons/icon_confused.gif[/img]
Let's go racing!
www.outlawpontiacs.com/members/B-Man2.php
www.outlawpontiacs.com/members/B-Man.php
Old 10-02-2002, 08:25 PM
Tim Corcoran's Avatar
#16's ported by Pete McCarthy, 2.19 Manley intake valves and 1.77 Ferrea exhaust valves. Flow sheets from SD Performance say they flow:
average of all ports on the intake side is 288.45 at .550 lift measuring at 28" of water. Best port flowed 290.60 worst port 286.30
average of all ports on the exhaust side is 194.6 at .600 lift measuring at 28" of water. Best port flowed 201.2 worst port flowed 188.10
The exhaust is a little weak but the intakes aren't bad for a D-Port [img]/infopop/emoticons/icon_smile.gif[/img]
Tim C
65 LeMans 11.06@121
Tim Corcoran
Old 09-19-2002, 09:49 AM
rompn63's Avatar
rompn63 rompn63 is offline
I run 980's on the Redskin. 2.02" intake 1.76" exhaust 3665lbs 9.96 @ 135
Old 09-17-2002, 06:17 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
72cc E-heads
Old 10-20-2002, 04:50 PM
72cc Eheads on current motor, #614 RAIVs previous two shortblocks in the '78 car
Stone stock '78 6X-8s in my son's '81.
Old 10-19-2002, 04:46 AM
Hey Chad my 68 Bird weighed approx 3600 pounds,8 inch convertor ATI,4.10 gear,31 by 13 inch tire.Convertor slip was a little over 4 %.I think anything under 5 % was supposed to be good.Im sure we can hook up next year!!!
Old 09-17-2002, 05:00 PM
RH152 RH152 is offline
Eheads on my 9sec grand am #96rd ports on my 67 firebird 11 sec car
pure pontiacpowerd 86 grand am
455 eheads hyd. cam 9.24 at 145
455 eheads solid flat tappet cam 8;95 @152
HOFFMAN RACING
Old 09-17-2002, 04:35 PM
head #96's Avatar
head #96 head #96 is offline
I use stock 96s, but everyone probably knows that from my user name. Runs 12.50s at 108.
best 1/4-11.37 @ 118.03, 96 heads on motor. 11.05 @ 120 on 100shot.
Old 09-17-2002, 09:08 AM
WARPed's Avatar
WARPed WARPed is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by b-man:
Let's go racing!
www.outlawpontiacs.com/members/B-Man.php<HR></BLOCKQUOTE>
Hmmmm, I would say the race only car [img]/infopop/emoticons/icon_razz.gif[/img]
with out questions there can be no answers
1969 Grand Prix
[email protected](1.358)
[email protected](1.342)
WARPed Tepee Forums
[email protected]
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 09-22-2002, 09:14 PM
Exactly look at Neil Owens,Bob Maxi,Nunzi,Mike Vocey,Mckinneys ect.Those guys haul a##.
