Old 07-19-2005, 05:49 AM
trans am ed trans am ed is offline
has anyone used this to repair intakes or thanks cases.
http://www.alumaloy.net/
Old 07-19-2005, 03:22 PM
Big Injun's Avatar
Big Injun Big Injun is offline
Have not used it but the demonstration on welding a beer can was direct from late night TV.
Dave "Big Injun" Anderson
[email protected]
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 07-19-2005, 08:45 PM
I have some of that stuff I got years ago, it was called THS 147 or something like that..still have a few sticks of it in my tool box...I can tell you the coke can deal is real...pounch a hole...heat can put rod on hot can and it will flow like water and not drip into the hole, it just covers it and then try to smash a hole through the weld and it will flatten the can....How ever if you are making repairs on thick stuff, you have to be sure its really clean, and parts that have been exposed to oil and carbon have to be heated to get the stuff outa the pores or it wont weld it up...but yes the alumalloy does work like it says it does....I even made repairs to carb bodies with it...you just have to be REALLY careful with your heat...the stuff melts at almost the same point as teh material you are working on melts.
Mike
