Old 06-07-2005, 04:13 PM
cdnroundport cdnroundport is offline
Incedible car from what I see quickly,gas tank straps were black and have oversray(I have seen 73 firebird with straps that had black paint then,red oxide then body colour)Rear sway bar looks black (most likely phosphate,similar to brake master and calipers?).front spindles look to be natural steel but have been shotpeened.front sway bar natural cast steel.I have access to a 42k 1973 and a nice 1972 from Nevada.I just removed the original clips from the 72 if anybody needs details.maybe we could use this thread for comparing original 70-73 firebird plating,clips,routing,paint process,markings,undercoating ect.what is the deal with 1972 seat belts?what type does you car have ?could you include build date for referance?My e-mail is [email protected] if anybody wishes to swap nut and bolt,fanatical T/A facts and info.
Old 06-07-2005, 06:19 PM
njsteve's Avatar
njsteve njsteve is offline
The straps look to be painted flat black. The tank was painted flat black also. I am assuming that someone did this over the last 33 years. Am I wrong? The car was a December 71 built car. What are the diferent seat belt styles so I know what I have? They do have a long plastic sleeve on one side if that matters. -NJSteve
Old 06-12-2005, 04:46 PM
njsteve's Avatar
I just disassembled the front subframe. Here are some of the details (still greasy) that I found. Here is the original paper tag on the passenger side front coil spring, part number 3988100:
The Following User Says Thank You to njsteve For This Useful Post:
Old 06-12-2005, 04:49 PM
njsteve's Avatar
Here is the driver's side front spindle. There is green paint near the upper ball joint area and a yellow paint line by the spot where the lower control arm metal stop hits the spindle.
Old 06-12-2005, 04:51 PM
njsteve's Avatar
Here is the driver's side front rotor. It has a white or light blue paint daub on the outer cone area where the wheel bearing cap attaches and orange paint in the area where the minimum thickness number is cast in.
Old 06-12-2005, 04:53 PM
njsteve's Avatar
Here is the passenger side rotor. It has a white paint daub plus a green one next to it. The inset portion of the rotor that has the minimum thickness number cast in it, is painted pink.
Old 06-12-2005, 04:55 PM
njsteve's Avatar
Here is the pass side spindle. It appears to have a light blue paint mark in the same area as the green one on the driver's side spindle.
Old 06-12-2005, 04:56 PM
njsteve's Avatar
Here is the drivers side inner tie rod with a dark geen paint mark on the tube.
Old 06-12-2005, 07:07 PM
Is the original engine harness with the car?could you look and see if turbo 400 switch is on gas pedal (is this how shaker is actuated?)
Old 06-12-2005, 07:20 PM
njsteve's Avatar
The original engine harness was melted beyond recognition after the prior owner had a major carb fire...but the car still ran. I guess you can't kill a Pontiac with fire! Someone took the kickdown switch off of the gas pedal but the harness was still there under the dash. Crispy parts of the underhood wiring were also still hanging from the firewall in the engine compartment. And yes, the 72 T/A's used the gas pedal mounted kickdown switch, even on 4-speed cars. Shaker wiring became a whole lot simpler in 72, with a major reduction in extraneous switches, wires and brackets on the carb.
Old 07-01-2005, 11:45 AM
pmdclassics's Avatar
pmdclassics pmdclassics is offline
I am about to tear down my 70 T/A and am going to start with the fenders. Is it just the visable nuts and bolts holding the fenders on?
TODD
Old 07-01-2005, 05:21 PM
Formulabruce's Avatar
my 73 is a red car and the overspay isnt so noticeable I may have some pics of the untouched primer, but these are super, and a 72, thats so sweet, beautiful car!!
" Long may we DRIVE !"
Old 07-01-2005, 06:10 PM
guess my 5 meg camera cant take a small enough pic in file size to post here ugh, off to a photo program hehe
Old 07-01-2005, 07:01 PM
Jeff R's Avatar
Jeff R Jeff R is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by pmdclassics:
I am about to tear down my 70 T/A and am going to start with the fenders. Is it just the visable nuts and bolts holding the fenders on? </div></BLOCKQUOTE>
Yes, all the bolts are fairly obvious. 4 from the top side inside the engine compartment, one of which goes into the firewall behind the hood hinge...6 if you count the bolts holding the hinge. The rest are along the lip of the fender and along the lower edge. Then there are two that go into the middle of the wheel well from the underside.
Old 07-01-2005, 07:15 PM
eaglesan13 eaglesan13 is online now
Can the fenderwells be removed from my 70 trans am without removing the fender? My a/c box on the firewall is broken and I want to replace it without removing the fender if possible.
Old 07-01-2005, 09:07 PM
Jim Rotella Jim Rotella is offline
eaglesan13,
The passenger side inner fenderwell can be removed without taking off the fender. You'll have to remove the lower front and rear fender bolts and pull the lower portion of the fender outwards. Make sure that you jack up the car as high as you can get it and remove the wheel. The fenderwell should come out with a little jockying. I rotated it a bit until I found room enough to pull it out.
Jim.
Old 07-02-2005, 08:23 AM
Thanks Jim!
  #38
Old 07-02-2005, 05:15 PM
njsteve's Avatar
While pressure washing the frame I found something interesting. The paint came off rather easilt and on the passenger side inner frame rail at the rear, was a part number hand printed with a magic marker.
  #39
Old 07-02-2005, 05:16 PM
njsteve's Avatar
Here is the number right side up.
  #40
Old 07-02-2005, 05:18 PM
njsteve's Avatar
Here it is upside down. Any body out there know what this number is? Looks like a 5236 44. Does this correspond to anything?
