Old 04-13-2003, 04:54 AM
timbergrove timbergrove is offline
The windows and interior are removed. The headliner is on its bows with the ends hanging down. How do I stretch the vinyl headliner to get the wrinkles out and glue it along the edges.
I suspect heat will help remove the wrinkles, but how can it be stretched and glued at the edges at the same time??? There are no clips or tack strips, just a channel into which the liner is glued.
Your hints will be appreciated VERY much.
Thanks,
Bob
There are 10 kinds of people, those who understand binary and those who don't.
Thanks,
Bob
Old 04-13-2003, 06:05 AM
Txbobcat Txbobcat is offline
Heat will remove many wrinkles. Usually there is some cardboard of round material that you wrap up with the headliner material then push into that groove which holds it in place.
