Old 06-20-2005, 05:47 AM
Rugratman's Avatar
Rugratman Rugratman is offline
I went from 85#'s to 79#'s in the front primary's on my Demon 850.
It's like driving a brand new engine.
Idle is better, car run's so much smoother, unbelievable the difference it made. Oil, voltage, I lost that gassy exhaust smell.
The #85's are what was in the carb from BG.
I'm so happy, I had to tell someone, my wife just didn't care....
........I'm just learning as I go.......
Old 06-20-2005, 05:56 AM
YEa, sounds great. My efforts start out rich, then lean-up with run time on the road.
Secondary, then Primary, then Idle.
Along each adjustment, I reconsider the Initial timing. Just to match the off-idle response to the pump gas ping.
I Wrestle the High-Compression Primary&Idle recipe on: Rich&Advanced or Lean&Retarded. To the tune of having non-linear timing & a non-linear misture.
Q-Jet Part-Thrittle Enrichment circuit allows the Fat/Lean vs load, while the HEI initial Advance comes in early and stays put above 2500RPM.
I got my hands full with the 8.3:1 Mixture & Timing shedules. HIS
Old 06-30-2005, 08:05 PM
fastgtr fastgtr is offline
Hallelujah! I jetted down to 78's and 86's and had the same result. Woke the car up BIGTIME. even 80's are too big for my 455 with RA IV Cam rgoads lifters, balanced and blued 4 bolt block. Also saw idle quality improve and backfiring subsiding remarkably.
If your ears ain't bleedin'...
It's VOLUME your needin'!!!
I like to Turn it up to 11...Nigel Tufnel...Spinal Tap
Old 06-30-2005, 08:43 PM
firechickenman's Avatar
firechickenman firechickenman is offline
I've found the "sweet spot" for my Holley 800 DP using a wideband O2 sensor. 70 pri. with a 6.5 PV and 84 sec. PV blocked. Before I had the O2 sensor, I was running 77/85. Now it's a whole lot nicer to drive on the street, plus I knocked .3 off my 1/4 ET!
Greg Weigart
IAIIA 520/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radial Pro/3300lbs/1.35 60'/[email protected]/[email protected]
Hot Rod Drag Week finishing averages:
2014 - 11.12 @ 118.56
2015 - 10.84 @ 124.97
2016 - 10.56 @ 127.88
2017 - 10.29 @ 130.74
2018 - 10.29 @ 130.53
2019 - 10.16 @ 132.34
2021 - 10.09 @ 132.69 - Quickest Pontiac
2022 - 10.13 @ 133.07
2025 - [email protected] - 2nd place SRBBNA
Old 07-01-2005, 07:44 AM
george kujanski's Avatar
Rugratman: wives are like that. They only get excited about their next pair of cute shoes which they will complain about later that their feet hurt.
george
Old 07-01-2005, 09:45 AM
runningbwdog's Avatar
runningbwdog runningbwdog is offline
Hi,
How are you using an O2 sensor to determine your air-fuel ratio???
Do you have O2 sensors in your exhaust pipes (where?) and what type of instrument are you connecting them to?
I'd like to know if my jetting is correct also.
Thanks,
Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels
Old 07-01-2005, 11:01 AM
I'm using the Innovate Motorsports wideband with the RPM kit. Best money I ever spent on my car! I have the O2 sensor mounted in the crossover pipe so it can read both banks.
LM-1
Greg Weigart
Old 07-01-2005, 01:54 PM
ER's Avatar
ER ER is offline
Rugratman, what made you decide to change jets ? Were your plugs fouling ? I'm thinking I may need to change mine too but my plugs look fine.
ER
Old 07-01-2005, 05:40 PM
amcmike's Avatar
amcmike amcmike is offline
Rugratman, congratulations! Typically the aftermarket carbs are jetted rich for most applications (probably a liability thing).
I had the same experience with my Holley 3310. Dropped 4 jets sizes on the primaries and the part throttle and wide open AFRs came right in where I wanted them. Didn't even have to touch the secondaries (thankfully - I hate those cheap plates they used in place of real jets).
Car ran better and used less fuel (when being gentle of course).
Strangely, my wife wasn't excited either. Kind of kills the thrill of victory feeling.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 07-01-2005, 07:11 PM
I have 74 pri and 84 secondaries in my hp950 think im going to jump it up a notch LOL.
Mike
Old 07-01-2005, 11:20 PM
SergeF SergeF is offline
LouisianaGuy, I am running same hp950 carb with 78 jets front and rear. I did 74 front and 77 rear, power valves present but no street driving yet. What was your reason for a change? Just curious cause i am trying to fix rich condition
at low speeds. Thanks
Old 07-02-2005, 05:56 PM
Serge, I got the carb like that it was onan E-head 455, dont know if they jetted it like that or it came that way...I dont have a rich problem really, 74/84 I believe...I have to take it apart as I have a screw leak and would like to put new gaskets for grins.
Mike
Old 07-02-2005, 08:53 PM
6567GTO's Avatar
6567GTO 6567GTO is offline
firechickenman - glad to hear about your thumbs up to the Innovative Sports system. I installed a bung on each collector for this exact purpose. I'm trying to figure out whether to go to a chassis dyno or pick up one of the Innovative kits now. With what it would cost for one session at the dyno I could have one of these kits forever.
_________________________
Sonny Barger
