Old 01-07-2001, 12:19 PM
66temp 66temp is offline
Please help. I just bought a '66 tempest custom. the blower doesn't work. Any ideas would be helpful.
Old 01-07-2001, 05:23 PM
jim darlington jim darlington is offline
Check the following...
the fuse , switch assy , blower motor itself , the wiring may have a short in it or a bad ground . Good luck and welcome to the board
Man is not complete until he's married , then he is finished !
Old 01-07-2001, 09:21 PM
jim,
Any ideas where to get wiring diagrams? What's the best way to get at the switch. I do know I'm not getting juice to the motor.
Thanks.
Dave
Old 01-08-2001, 11:47 AM
rannca rannca is offline
I have the same problem, I have replaced the switch and verified my motor works, but still not through the switch, to get at the switch you have to remove your radio and 8 track ducting ,there are four nut's that hold the a/c dash panel in place, on ebay there are 66 service manual's that can be purchased and those manuals have good info and wiring diagrams..good luck keep us posted.
Old 01-08-2001, 02:32 PM
Ed Neasham Ed Neasham is offline
Hey, while we are using Performance Years good auspices, let's give them some business. They sell the Service manuals too. The manuals are your best investment, but there are also wiring diagrams only available for about 8 -1 0 bucks.
Old 01-08-2001, 04:00 PM
sorry Ed, your right, might find it cold outside this b.b. has been alot help, as Ed said check with PY first.
never intended to disrespect.
Old 01-09-2001, 12:38 PM
Ccass's Avatar
Ccass Ccass is offline
Administrator
Once you get at that switch, I have had some luck taking the back terminal plate off and cleaning the contacts, re-greasing and putting back together. If it's totally trashed, I think we have several good used ones. If it's an a/c car don't forget to check the switch on the blower housing. They are almost always shot. (those we dont have)
Old 01-25-2001, 12:01 AM
TheTempest TheTempest is offline
Ccass,
What switch on the blower housing are you refering to? I have a '67 Tempest w/fact. A/C and the only "switch" I could find would be the relay (on the firewall) or the resistor block (located on the blower housing).
Mike
Old 01-25-2001, 10:47 AM
Ccass's Avatar
Administrator
The actual 4 position electrical switch on the dash heater control unit. It has the chrome handle.
Old 01-25-2001, 12:08 PM
ccass,
Do you know if py has any of the relays that are on the housing or where I can get one?
