Old 11-12-2002, 04:24 PM
trjackson10 trjackson10 is offline
I have a dash mounted sun tach in my 68 gto that i"m trying to connect to see if it works if anyone can help with the wiring i'd appreciate it. It has four wires, one to the distributor and one to groun . I think one of the other two goes to power but I don't know where the fourth goes. I can't find any diagrams anywhere for this.
Old 11-12-2002, 04:41 PM
428GTO70's Avatar
428GTO70 428GTO70 is offline
Send a message via MSN to 428GTO70
More than likely the 4th wire is for the light inside, To be spliced with a dash light wire. If it were mine I would try to connect it to power to see if it lit up, but thats me, and you are you. I take no resposibility if it fries something so make sure first if you have doubts! [img]/infopop/emoticons/icon_biggrin.gif[/img]
GR-RRR!
1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi.
Everything installed, fired up and tuning has begun!
Old 11-13-2002, 02:00 AM
Held for Ransom's Avatar
Maybe this link will help. http://forums.performanceyears.com/g...1&m=5886023911
So long, farewell.
Old 11-13-2002, 12:19 PM
thanks guys appreciate the help
