Old 11-05-2002, 07:39 PM
Bigred455 Bigred455 is offline
Here is the combo:
468 (4.185 x 4.25)
Rpm intake
Slightly prepped E-heads
Crower Hyd. 236/242 about .550" lift with 1.6 roller rockers on 108 lsa
850 HP series Carb
Would the Hooker Super Comps be too big with 2" primaries for my application? Also, this combo will get some spray, and larger cam later on down the road.... Would the large primaries be something I could "grow" into, or am I better off looking for a 1 7/8" hedman?
thanks, George Hill
George Hill
'63 Star Chief, '95 Chevy P/U, lots of BMW motorcycles and cars
Here is the combo:
468 (4.185 x 4.25)
Rpm intake
850 HP series Carb
thanks, George Hill
George Hill
Old 01-30-2003, 06:06 PM
PONCHOMAN PONCHOMAN is offline
I would have to say thay you shouldn't have any problem running the 2" primaries.
Old 01-31-2003, 02:43 PM
Fox Fox is offline
With the plans for additional mods to the engine I think you should just go ahead and get the 2" primary headers. With the current setup 1.875" primaries are probably optimal but why spring for 2 sets if you don't have to.
"Man did not weave the web of life, he is merely a strand in it.
Whatever he does to the web, he does to himself."
- Chief Seattle
Old 02-04-2003, 11:51 AM
Tough question.
The cam is the Intake bottleneck.
Since the Cam ovelap is low, you will have less sensitivity to EXH system woes. 1.65 rockers on both, and the 2"primaries will be OK. Headpipe and muffler system will need critical design to work with 2"Primaries.
1.63 1 5/8" good to 11.0 @ 123MPH
1.76 1 3/4" bigger
1.88 1 7/8" bigger yet
2" biggest
Small Primaries preserve EXH velocity, allowing less sensitivity to "full exhaust system" restrictions downstream.
"tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs
11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs
12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs
12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
