Just to let all of you know, dont waste your time with pertronix ignition, I did in my 68 firebird, and went nuts trying to figure out why it was fluttering through the carburator under a full load, thought it was the valves, adjusted them, then was told it was my carburator, then I called Jim Hand and he said, " Mike, take out the pertronix and re-install your points ignition" and now the car runs greeeeeeeeeeeeeeeeat!!!! thanks to Jim Hand I will now have a great summer.
My wife wants to know "Why do you feel the need to burn the tires like that" I said, its a guy thing honey. :} |
Interesting. Sold quite a few units (and installs) without any problems.
I bet over 50,000+ units have been sold to date...... And all bad? Build it fast, build it right, build a Pontiac. http://PontiacDude.cc |
My father had one in his '67 427/390hp Corvette adn it ran like a champ. He drove it from Boston allt he way to the end of Long Island and back and no hiccups at all.
have one in the SD as well ....no problems, either.
1973 SD455 T/A 1979 S.E. T/A http://community.webshots.com/album/16587603rOyvmFCiHs
Home of WFO Hyperformance Shaker induction. |
Pertronix ought to work.
However, I use HEI. HIS "tbdET/1xxMPH/1.xx 60foot/28"/3.54:1/10"/469 #48/Flat HYD/DualQ-Jets/Offyl/3xx0Lbs 11.00/123MPH/1.50 60foot/29.5"/4.10:1/10"/469 #48/FlatHYD/DualQuad/Wenzler/3250Lbs 12.00/112MPH/1.61 60foot/26"/3.31:1/10"/469 #48/FlatHYD/Q-Jet/Torker/3650Lbs 12.70/103MPH/1.71 60foot/28"/4.10:1/12"/469 #48/FlatHYD/Q-Jet/Torker/3950Lbs"
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Possibly it was just a bad module it can happen. Replace it under Warranty & re-install & you should be ready to go. We sell tons of these things with very few problems like others have said.
Put on in my fathers 67 GTO 4 years ago no problem. I know of a couple guys that had problems due to the ring rubbing the pickup.
65 GTO, Tiger Gold, Nostalgia Super Stock 421, 2-Carter AFB carbs, Stock Suspension, 3550lbs Full Exhaust-- 9.70's@135 66 GTO (Retired race car) 421 CID Multiple NSCA/NMCA World Champion 66 GTO 389 3x2, 4 speed, 3.90 gear, Montero Red 33K original Miles 67 GTO 2dr Post, 428, Tri Power, 3.55 Gears 80 Trans Am Black SE Y84 W72 WS6 |
I have the Pertronix HEI. It has worked great for about 4000 miles.
http://kurtspontiac.homestead.com/DavidJones69GTO.html
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core.
I have one in both my tempests,also my RA V T/A.I guess I have been lucky.Tom
I have had a Pertronix module in my Firebird for 6 years. The car has made over 300 passes down the 1/8th mile and has over 30,000 miles on the street. I have had direct coil voltage arcing to the negative terminal of the module when a coil went bad and the module still works perfectly. Sounds like you got hold of a bad module. Glad things are going well for you though, I know how it feels to not be able to drive.
Joe |
Have installed and sold a number of Petronix units on many brands of cars and have had no complaints about the unit and NO come backs.
Petronix has worked GREAT for me. I solved all of my car's electrical problems!
http://f1.pg.photos.yahoo.com/[email protected] |
I tried putting one on my Sunbird. Damn thing wouldn't fire. I was on the phone with their Tech trouble shooting it for some time. Bad module!
Dropped in an HEI and fired right up. My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
Well Iam glad all or most of you had good luck, its so frustrating when something like that does not work and causes a bunch of grief. I was worried I was going to lose another summer. Anyway, I called summit racing and they are more than happy to warrenty it for me, those guys at summit are very professional, glad I got so many responses.
Yeah, I realize that the Pertronix has been out longer, but the Hall effect design and stock external appearance (single wire to the negative side of the coil - just like points!) of the T.I. Specialties/M&H system is the way to go. PY sells 'em for $139.
I'm NOT dissing the Pertronix, heck I've never used it. But, using this system and a stock Delco coil, my Formula lights off at the first twist of the key EVERY time. Went 12.96 @ 104 on my 10th pass with the new engine! Gapped my R43TS plugs @ .040" BTW. Just my .02 worth! Lloyd '72 Formula 455 - TH400, 3.08 posi, A/C, Y99 suspension, tach & gauges, AM-FM stereo, 8-track, Formula steering wheel, etc.; Lucerne Blue with Medium Blue deluxe Interior; 12.96 @ 104 MPH @ the '03 PSN's Someday I'll be restoring a '72 GTO 455HO, TH400, A/C, etc.; Sundance Orange with Parchment buckets
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
I installed a pertronix in my stock points distributor. Just set it up properly and you won't have any problems unless there is something wrong with the module.... which could happen to any electronic module.
Find out what the problem is before dissing a product. |
I just dropped in a pertronix flamethrower hei and it works great so far also.
GR-RRR!
![]() 1970 GTO 458 CID .040 over 4 Bolt 428 Block, Forged Eagle 455 Crank, 295 CFM SD KRE D-Ports, SD Old Faithful HR Cam + Comp HR Lifters, PPR Maxx-lite rods, Racetec pistons, PRW 1.65 SS Rockers, 900CFM Holley HP TBI, Performer RPM, Hooker Super Comps, 3" X-Pipe into 2.5" mufflers/tailpipes, 2.75 1st TH400, Continental 13" Converter, 8.5" 3.08 Posi. Everything installed, fired up and tuning has begun! |
I have used pertronix for years. YOU MUST CHECK THE RESISTANCE OF YOUR COIL!!! If you don'nt have at least 1.5 ohms resistance, you must put a ballast resister in line. Doublecheck with pertronix on that figure i gave above. Also, make sure you have a good 12V source for the Pertronix. Do'nt use the original point wire as the resister in line will drop the voltage to 8-9 volts after the car starts!!
74 GTO 406 T400 74 Firebird 350 4-speed 68 GTO Convertible 400 T400 76 GP LJ 400 4BBL T400 78 Chevy 1/2 Ton Truck
74 GTO 406 T400 74 Firebird 350 4-speed 68 GTO Convertible 400 T400 76 GP LJ 400 4BBL T400 78 Chevy 1/2 Ton Truck Oh yea I love my wife very much For some reason it got erased when I put it here last time!!!!!! hmmmmmmmm |
Ditto on trashing. My 66 GTO NEVER EVER ran better! Ask anyone who knows, really knows engines......points suck! After 4,000 rpm points blow! Duh, I knew that in 11th grade....in 1972!
Ever think the module is bad???????????/
1966 GTO |
