Old 11-16-2004, 08:18 PM
SneakyPete SneakyPete is offline
Hello all, i am wanting to convert my Bird to a manual. I know alot of you are gonna say put a tremec in it, but that just is not in the budget right now, maybe in a year or so i can go that route. But i figure i can still do everything i need to do to convert it and run a st-10 or muncie for now, then put the tremec in at a latter date. Anyhow i have a chance to buy a M-21, will this hold up to a poncho 400 that is built fairly stout if i dont hammer on it to much? If it wont do does anyone have a st-10 laying around that they want to sell? or another manual tranny that would work?
On a side note if anyone has a good flywheel they want sell let me know.
Thanks Pete
1969 Firebird, 406 cid, #62's flowing 243 int - 215 ex @ .500, Torker II, Edelbrock EVS Thunder 825 cfm carb, MSD Dist & box, Big HYD cam(too big), 4 Tube Headers into 2 1/2" Duals, TH400 tranny with 3500 stall, 9" rear end with 3.90 gears, MT Indy Profile Tires 28" tall. Best run 12.43 @ 111.
Thanks Pete
Old 11-16-2004, 08:27 PM
STXJudge STXJudge is offline
I think you'd have to be a little more specific than "a little stout." The M-21 was able to stand up to the torque of a RAIV Judge at the very least. I'm sure it can take more than that.
Old 11-16-2004, 08:43 PM
400 block .30 over, #62 heads ported-flow @.550=246 intake and 226 exh. Torker 2 port matched, 8oocfm avs thunder series carb, cam= duration @ .50 is 246.4 int & 254.9 ext, lift=.54343 int & .54923 ext, Lobe Seperation is 110.1. 4 tube ceramic coated headers. Ford 9 inch, 2 center sections both detroit lockers 3.15 and 3.90 ratios. I am thinking about putting a milder cam in it, but still havent decided on that yet. Sorry about the lack of details.
Old 11-16-2004, 09:10 PM
tom s tom s is offline
if you put slicks on the car and really get it to hook,you will be breaking a trans with either a M-21 or a ST-10.A aftermarket BUILT trans may be better.Tom
Old 11-17-2004, 09:55 AM
Junkyard Dog's Avatar
By the time you build one strong enough to take slicks, you could have bought yourself a Tremec . . .
If you are just running around on street tires, get the Muncie. Keep in mind, though, that the M-21 ratios are ridiculously narrow compared to modern transmissions. I wouldn't bother with it unless you are going to install 3.73 gears or lower in the rearend. The first gear on a Muncie M-21 is a very tall 2.2. You do the math.
You might be better of with an M-20, which has a first gear of 2.52. I have one with a 3.55 gear, and it drove very nice with a torquey, mild 455. The ratios STILL seem too close, though, if you are used to modern transmissions.
I think the new Tremec TKO 600 has a 2.66 first gear, but a .64 overdrive. That would run very nice with rear gears in the 3.73 to 4.30 range.
Badder than old King Kong
-Jim Croce
Old 11-17-2004, 10:17 AM
If you keep an eye on classified you can sometimes find a Doug Nash for less than $1000.Checking Superstockforums.com I've seen some there also.
Old 11-17-2004, 01:35 PM
Well i guess i will just hold off on this project for awhile. I have done alot of reading in the last few hours on the net, sounds like the 5 speed is the way to go. Might as well do it right the first time. found a site that has the tko500 with everything i will need to install the tranny including driveshaft for $2300.00. I will just have to hide more money from the wife for the next few months so i can get it. Sure would be nice if Santa would leave a TKO under the tree for me
Old 11-17-2004, 07:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by JunkYard Dog:
<HR></BLOCKQUOTE>
True!
Old 11-17-2004, 08:42 PM
GOATEY69 GOATEY69 is offline
I have a BW S-T10 out of a late 70s TA with a 2:43 first gear.I also have a flywheel. Trans shipped $450 , flywheel shipped $100, both shipped $525 It would be best to email me at [email protected] Doug
