Old 11-20-2004, 08:21 PM
Read the link 242177P gave above.
The dynamic compression ratio will always be lower than the cr.
It is also dependant upon the cam that is being used. A wilder cam will have a lower DCR than a milder one will have generally. (LSA and duration etc will affect it)
Old 11-20-2004, 08:23 PM
grandville455's Avatar
Here's the #'s
4.19
4.21
98 c.c
.005
.039
6.6
.1
.0028
6.625
290
112
+6
Darby
M/T 275/60 ET SS Drag Radial
Old 11-20-2004, 11:24 PM
MasterGore's Avatar
MasterGore MasterGore is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by grandville455:
Here's the #'s
4.19
4.21
98 c.c
.005
.039
6.6
.1
.0028
6.625
290
112
+6 <HR></BLOCKQUOTE>
It was in fact an error in my formula. I was adding the cam advance to the valve closing angle instead of removing it. An advanced cam makes events happen sooner, not later.
I also forgot to double up the advance to convert from cam degrees to crank degrees. I've fixed it and it should give you a more accurate result now.
Adding a field for cam advance was just an afterthought, and I forgot to debug it properly. I'm glad someone spotted this error Based on the corrections, you should have 9.3:1 static CR and 7.46:1 dynamic CR. That makes a whole lot more sense
1977 Trans Am SE W72 4sp, 95% original
Old 11-20-2004, 11:55 PM
Yes it does ..thank you
Darby
Old 11-21-2004, 12:27 AM
MasterGore's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by DiamondJim:
Is there any way to add a field where you could just enter intake closing so it could be used with dual pattern cams? <HR></BLOCKQUOTE>
Consider it done! I've added the option to either have the calculator determine valve closing angle, or to type it in manually.
I'll try and tweak the calculator over the next few days to make it more user-friendly. Thanks greatly for the input!
Old 11-21-2004, 08:42 AM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
Looks much better now and agrees with Pat Kelleys DCR calc program. Nice job!
Old 11-21-2004, 09:32 AM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
Goremaster, You Da Man!! -Jim
Old 11-21-2004, 11:08 AM
DiamondJim's Avatar
Is there an easy way to move it so it prints out better? Not complaining, I hope you don't mind my suggestions. -Jim
Old 11-21-2004, 01:20 PM
MasterGore's Avatar
Is there an easy way to move it so it prints out better? Not complaining, I hope you don't mind my suggestions. -Jim <HR></BLOCKQUOTE>
Constructive criticism is always welcome
But I'm not sure I understand what you mean exactly. Are you referring to physically printing it onto paper? Or the way it lays itself out on the screen? If you're referring to actually printing it onto paper, there's a "Print" link near te top of the page (to the right of the page title) that opens the page up into a new window without any graphics or navigation stuff.
I've also removed the right blue column from just that page to reduce the displayed width a little. It should fit better in all resolutions now.
Old 11-22-2004, 11:49 AM
fiedlerh's Avatar
fiedlerh fiedlerh is offline
I run a couple of Javascript programs on a couple of corporate website and I haven't had any complaints yet about it not working. I just put up a message like "This feature requires that you have JavaScript enabled in your browser settings."
I see you already did that.
http://www.pontiacpower.org/
Old 11-22-2004, 05:42 PM
DiamondJim's Avatar
OK, I'm blind, didn't see the print button- DOH! -Jim
Old 11-23-2004, 07:49 PM
BVR421's Avatar
BVR421 BVR421 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by GoreMaster:
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by BVR421:
nice calculator but javacrap is not welcome on a lot of computers <HR></BLOCKQUOTE>
Criticism is good, but only if it comes with explanations. <HR></BLOCKQUOTE>
I have always had generally negative impression of javascript and its uses. thats speaking as an enduser only. often silly uses similiar to flash animations. your calculator certainly doesnt belong in that category.
sorry I have no programming expertise nor math skills and I admire those who do so dont take it personal. I wouldnt presume to recommend any other vehicle than what you have chosen
Old 11-23-2004, 07:54 PM
BVR421's Avatar
projectpontiac.com seems to down or is it my dumb browser?
Old 11-23-2004, 08:15 PM
Judge not's Avatar
Judge not Judge not is offline
It does not work for me either
"A government big enough to give you everything you want is a government big enough to take from you everything you have." Gerald Ford
“The problem with socialism is that you eventually,
run out of other people’s money.” - Margaret Thatcher
Old 11-24-2004, 04:49 AM
Bud Lyons's Avatar
Bud Lyons Bud Lyons is offline
Send a message via MSN to Bud Lyons
Deader then a hammer!
WWW.PatriotGuard.org
Standing for those that stood for us.
Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I.
One for your soul; the other for your freedom
Old 11-24-2004, 11:25 AM
It's working now.
He probably had too many visitors and passed his limits.
Old 11-24-2004, 09:57 PM
BVR421's Avatar
screw that! now he wants to plant cookies on my hard drive
Id rather use an abacus
  #38
Old 11-25-2004, 11:50 AM
Formula jg Formula jg is offline
Can someone confirm if the 400 Eagle stroker kit with the JE piston set has 9cc valve reliefs? What is the Piston Ring Height for the JE's?
Old 11-25-2004, 11:53 AM
Also,
I have a solid flat tappet Crower #60310, does anyone know how much advance is manufactured into the cam?
Thx.
  #40
Old 11-25-2004, 01:35 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Great site!
Works in Mozilla just fine along with IE. JavaScript is not an issue if you set your browser correctly and cookies - who cares.
Thank you for all your hard work.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
