Old 05-22-2004, 11:04 PM
arm019 arm019 is offline
69 GTO, when i put on the dash lights, headlights, or turn signal lights, my gauges (oil, fuel, temp) all go to zero. Any suggestions would really help! Thanks!
Old 05-22-2004, 11:39 PM
cuz68's Avatar
cuz68 cuz68 is offline
Welcome to py arm019. It might be the ground on your dash lights.
Cuz68
Old 05-23-2004, 05:05 AM
goathead68's Avatar
goathead68 goathead68 is offline
Yeah, check the grounds. A good investment would be the factory service manual for your '69; there's real detailed wiring diagrams in that book's 'electrical' section.
Old 05-24-2004, 08:05 AM
thnaks for the advice. I thought it might be a ground problem. Does the headlight/dash light switch have a ground coming off of it? I think that it is just a switch and the lights are each grounded at their respective positins. Any more info would be great! Thanks for the advice about the service manual too! Any idea where I can fund an assembly manual for a 69? They don't seem to exsist!
Old 05-24-2004, 10:04 AM
engineer engineer is offline
no assembly manual for a 69 is available. You need the service manual or buy the CD.
Old 05-24-2004, 07:53 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Sure sounds like the ground for the gauges. your probably picking up a ground through the gauge light bulb filiments to make the gauges function until 12V is supplied to them. Do the lights come on on the gauges when you pull the switch? I have a complete harness in the basement I can check to tell you where the ground wire is if it will help.
68ragtop
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 05-25-2004, 06:22 AM
the dash lights do come on, somewhat dim though, but when I put the dash lights on, the highbeam red light and both dash turn signal arrows illuminate, somewhat dimly too. I agree that it is probably a grounding issue, but the problem is that I do not know how it is grounded? Is there a grounding srtap? a wire? a ground throught the print circuit for the dash? Are the dash pods induvidually grounded? These are the questions that I cannot figure out yet. Any more help is really appreciated. Thanks
Old 05-27-2004, 10:48 AM
yep, it was a ground problem. The metal strap that connects the instrument pods was just laying on hte side ot the pod and not firmly connected to it. THanks for all your help!
Old 03-07-2011, 11:44 AM
bluebeast's Avatar
bluebeast bluebeast is offline
arm019, did you get any pictures of the ground strap you were missing?.I'm having the exact same problem with mine.
Old 03-07-2011, 01:36 PM
gto4evr gto4evr is offline
I don't think he's going to hear you, his last activity was 2005!
The ground strap is a flat thin sheetmetal loop with eyes at both sides. You can simply duplicate it with piece of 14 gauge wire and two eyelets if yours is missing.
Old 03-07-2011, 02:04 PM
bluebeast's Avatar
where does this ground strap attach to,I don't see anything in my service manual about this.I tried grounding the cluster,and they are brighter.Does anyone have a diagram to show where this strap goes.Would'nt the cluster by be grounded by the dash which is attached to the body
Old 03-07-2011, 02:40 PM
SONIC 4 U's Avatar
SONIC 4 U SONIC 4 U is offline
A strap runs from the bottom corner of the gauge cluster to the wiper switch. Also if you have a clack, a strap should connect it to the gauge pod. This is very typical. Honestly I usually run a wire from the housing to the steering column to ensure a complete ground. If you painted the back of your housing when you did the restoration, this could be the main cause of your problem. I always had my housing plated to ensure this problem didn't happen. Also make sure all your ground straps are on your engine and are tight
http://www.AbsoluteCleaner.com
Old 03-07-2011, 03:46 PM
Peter Serio's Avatar
Default Ground Strap(s) location.
The Ground Straps, 1969-1970
ID:	236949   Click image for larger version
ID:	236950   Click image for larger version
ID:	236951   Click image for larger version
ID:	236952   Click image for larger version
Peter Serio
Owner, Precision Pontiac
Old 03-08-2011, 10:47 AM
bluebeast's Avatar
thanks guys,the ground seemed to help.Hopefully that will cure the headlights draining my battery too. The blue paint inside the instrument pod is that special paint .I know you never see it ,but it has little surface rust on it
Old 03-12-2011, 10:31 AM
Here's a pic of the actual ground straps...this is a '68 pod.
Old 03-12-2011, 03:35 PM
bluebeast's Avatar
that's a good picture,THANKS.Is that a tach or clock it's attached to?
Old 03-13-2011, 05:10 AM
Reproduction factory tach. Never seen the backside of an actual factory tach so I don't know how accurate that black wrinkle finish with the black wire is...Probably not very.
I was posting you you'd see those stamped metal ground straps shown in Pete's drawings...Sometimes a photo of the items pictured helps.
