Old 12-27-2004, 08:16 PM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
Dose anyone know how long a 100,000 btu furnace will run on Propane? it is a dayton furnace the hanging type for a garage, Dayton sent me a valve kit to convert it from natural gas to propane, Id like to know how long it will run on propane so i can figure out how big og tank to get. it is an uninslated garage, and id like to have the tank big enough to run it for two mmonths jan and feb.
8.30 @ 165 mph 3,380 LBS
Ray Cox's Avatar
Old 12-27-2004, 08:24 PM
Brian Baker's Avatar
Given the fact that heat rises, I will never understand how hanging heaters for garages ever became so popular. Is giving up a little floor space really worth having a cold floor?
Old 12-27-2004, 08:38 PM
Goin' Topless's Avatar
Goin' Topless Goin' Topless is offline
Send a message via Yahoo to Goin' Topless
Depends on the efficiency rating, but I'd say it's gonna use a bunch! I got a 90,000 BTU natural gas furnace in my garage, partly insulated. Gotta finish that someday...
How big is the one in your house? If it's close, use the info they give you on the monthly bill and divide by however much time you think you'll be out there, 50%, 66%, 100%.
100,000 BTU will heat about 1500 sq. ft. pretty well.
Don't tell people how to do things. tell them what needs to be done and be surprised by their ingenuity. -- Gen. George S. Patton
Old 12-27-2004, 08:43 PM
Ray Cox's Avatar
Im sure its a lot, but whats a lot? the one in my house is natural gas I need to know how long it will burn on propane. Brian its a rental garage I rent to keep the cars in I took the furnace out off my old garage when I moved and dont want to buy a new one now
Old 12-27-2004, 09:03 PM
crossbreed455's Avatar
crossbreed455 crossbreed455 is offline
And I ask why would you want to chance it over to propane, it is more expesive than natural gas? To keep it at 45 i went thru a 25 tank in two days.
Old 12-28-2004, 04:17 AM
Jagtec1's Avatar
Jagtec1 Jagtec1 is offline
Propane had some of the highest increases in price this year VS. natural gas and oil. Any way you can stick with nat. gas??
Darin
'64 Bonneville Wagon (sold)
69 Lemans-All motor (sold)
9.81 @ 136.39MPH
Old 12-28-2004, 08:24 AM
Ray Cox's Avatar
I asked the COST! natural gas is not an option
KGTO's Avatar
KGTO KGTO is offline
Ray
Call me at my office. I own a plumbing and heating company. 406-728-3131
Then I can also ask you some questions about that short block you have
Basically there are some other factors to consider, but 1 gallon of propane = 91,800 BTU's, so just under 1 gallon an hour. A 500 hundred gallon tank can only be filled to 80% which gives you 400 gallons = 400 hours of run time if it ran non-stop. That's really out there though without knowing the actual heat loss of the shop and what teperature you aregoing to keep it at. It also depends on your design temperture at which your heat loss is performed. It should be realistic for the location. Around here we use a design temerature of -10 to -15 @ 70 degrees for a home, shops are usually kept cooler.
I would install a 500 gallon tank.
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @164 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 12-28-2004, 09:33 AM
tempest455's Avatar
tempest455 tempest455 is offline
Brian, a lot of it has to do with code. I just installed a 100,000 BTU Modine. It specifically states it must be installed at a minimum height (don’t recall specific height) per NFPA regs.
Ray I would get a natural gas unit if you can. My Modine is a high efficiency and it only runs 2 min per hour to maintain heat. If not, they offer a propane unit in the same spec. I will get the price and dealer if you would like.
FYI, if it’s shipped to a business with a dock, the freight is almost half!
Tempest455
Old 12-28-2004, 11:47 AM
Region Warrior's Avatar
Region Warrior Region Warrior is online now
RAY is looking to keep his "temporary rental" garage warm for winter. hasn't been able to find a bigger-better place to work. he probly would bump up the heat when out there. the furnace is installed, just need to get a tank & plumb gas line and exhaust. dosen't want to make investment because he may not renew rental after this season.
Old 12-28-2004, 12:20 PM
firebirdmi firebirdmi is offline
You should look into a hanging radiant heating system that uses gas. It will heat the objects (including the floor) in the garage, not the air. It's the same heating mode (radiation) that the old hot water radiators create in homes. Although it costs a bit more it is a more uniform and comfortable heating system.
Old 12-28-2004, 06:02 PM
goatman-68's Avatar
goatman-68 goatman-68 is offline
Ray
I would agree that a 500 gal tank is what you would need for two months of heat (uninsulated).
I would just call one of the local LP gas dealers and tell them you want to lease a tank for two months. It will cost you about $.50 a gallon more for their tank. Right now in central WI LP is going for $1.10 - $1.25 per gallon if you own your own tank.
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/[email protected] 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker.
Old 12-28-2004, 06:44 PM
Pontimaniac's Avatar
Pontimaniac Pontimaniac is offline
Ray,
I use a 75,000 btu on propane to heat 24'x 50'. I start it in late November and run it until the weather breaks. I usually keep it at 45-50 and just kick it up when I am spending time there. I have a 125 gal. tank and usually have it filled twice. The garage is all insulated and finished with 8' ceilings.
Old 12-29-2004, 10:12 AM
RAY, i just talked to one our tech's. he just jot his 100lb tank filled last month at TSC for $48. he also told me you have to keep the tank inside(warm)if used continously, or it will frost shut. also recomended you buy your tank, not rent it. i asked him about having to get it checked/certified. his is 10yrs old, and they haven't even questioned it.
Old 12-29-2004, 03:14 PM
Junkyard Dog's Avatar
Brian, I went duck hunting in Arkansas last year and the guide had his new radiant heat thing set up near the ceiling running off propane or natural gas, I don't know which. I, too, thought the heat would rise, but there is something about the design of this metal rectangle behind the heater that sent this heat all through this huge (40 by 100 or so) workshop. It was very toasty. Almost made it hard to go outside in the freezing cold to shoot ducks.
Badder than old King Kong
-Jim Croce
Old 12-29-2004, 03:25 PM
i have been told by a a/c-heater guy that heat draws to wherever cold is untill temp's are equal, even down. anyone out there in the industry know about this? not sure i belive it, but it does make sense.
Old 12-29-2004, 03:49 PM
Bill Eveland's Avatar
I run a hot water boiler on propane - 100,000 btu for my house and have a 500 ga tank. Usually they only fill it up 60-70% to allow for expansion. About every other month they come and fill it up in the winter . I would think a 500 ga would be more than enough , just have put in 200 ga or so.
Illinois Outlaw Gassers
6.27@107
9.97@131
