Old 05-04-2004, 10:27 AM
BigB's Avatar
BigB BigB is offline
455 bored .030, standard .030 trw pistons. Any ideas on max lift, with these pistons?
BigB's Avatar
Old 05-04-2004, 12:01 PM
Rob B's Avatar
Rob B Rob B is offline
I was running .570/.585 something gross valve lift with 1.65 rockers which would put it in the .620-.630(???) in a non decked 455 and still had well over an 1/8" clearance. My old TRW slugs and stock rods were also .030 in the hole.
Just changed to SRP pistons and H-beams rods that are basically at 0 deck. and still had plenty of clearance.
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
Old 05-04-2004, 12:45 PM
Old Man Taylor's Avatar
Don't forget that V-P clearance is also dependent on the duration of the cam. The larger the duration the less the V-P clearance.
Old 05-04-2004, 04:07 PM
Bruce Meyer's Avatar
Bruce Meyer Bruce Meyer is offline
Also dont forget different heads have different chamber depths. You have to factor that in.
Old 05-04-2004, 04:13 PM
255/265 duration cam at .050 on 106 c/l
with .594 intake and .618 gross lift, I
had about .140 on the exhaust.
This was with a TRW 2262 piston.
Old 05-04-2004, 05:23 PM
Heads makes a big difference as there can be 0.200 difference between a RAIV and a 6X-8 head.Deck height of the block also factors in.
Duration is the biggest factor and 8-12 degrees either side of TDC is the tighest areas.
On my RAIVs a zero deck block and 2262s a 255/259 @ 0.050 solid was close but OK a 274 @ 0.050 was way too tight.
You can add close to 0.050 clearance by blending the valve pocket out to the flat top in the middle of the "eyebrows". That ridge is where it hits.
Old 05-04-2004, 08:51 PM
Darryl Moreland Darryl Moreland is offline
My wife's car is a 455 .030 trw flat top motor with a Lunati 645 lift roller and 271-281 duration at .050. It has 62 d port heads on it.
Old 05-05-2004, 04:26 AM
BigB's Avatar
thank you everyone for your responses.
Old 05-05-2004, 07:54 PM
72firechicken 72firechicken is offline
I am running 87cc edelbrock heads with a gross valve lift of .633 .655 with trw rorged pistons and plenty of clearence, also revving the piss out of it.
Old 05-09-2004, 08:23 PM
wolf's Avatar
wolf wolf is offline
actually, overlap is the determining factor, not lift, nor duration. i.e. tightening up the lobe separation will reduce piston to valve clearance, all else being equal.
Old 05-10-2004, 01:55 PM
tempest455's Avatar
tempest455 tempest455 is offline
On my solid cam motor, I had TRW's -.012" in the hole w/ 72 cc E heads, .600" gross lift (.580" net), .039" gasket, 263/271, 108 LS (102 IC) and it had a mile.
Tempest455
