Old 07-09-2004, 03:29 PM
GOATEY69 GOATEY69 is offline
I have a 69 G.T.O.that I am building for a street/race car. I have a crank trigger and trying to figure out the best way to set advance curve. I went to MSDs web site and that brought up more questions than answeres. I have a 6AL that I can use with a timing computer. That is where the fun starts.Any body have any ideas on the best setup to use. I was going to buy a digital 6, but now not so sure if that is what I need. Thanks Doug
Old 07-09-2004, 04:48 PM
harry k's Avatar
harry k harry k is offline
Send a message via AIM to harry k Send a message via MSN to harry k Send a message via Yahoo to harry k
lol Goate69: do you know what MSD stands for ??
someone who thinks logically is a nice contrast to the real world.
http://www.youtube.com/watch?v=3FfKVVZW1-Y
Old 07-09-2004, 05:03 PM
bad69bird's Avatar
bad69bird bad69bird is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by harry k:
lol Goate69: do you know what MSD stands for ?? <HR></BLOCKQUOTE>
OK...I'll bite. What???
East Coast Mafia TTFMF
Making CVWHAT's great again. I guess it took a deplorable ECM member to do it!
Originally Posted by Ray Cox View Post
Holly cow we must be some dume corn huskers here in indiana or somthing!!!
Fastest Blow-thru Pontiac powered car in the Country [email protected] (3465lbs)
Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: [email protected]/ [email protected] (3365lbs)
Old 07-09-2004, 05:07 PM
Pontiac455 Pontiac455 is offline
Multiple Spark Discharge
MSD
Old 07-09-2004, 05:22 PM
bad69bird's Avatar
I knew that one. I thought that there was another meaning. Thanks
Old 07-09-2004, 08:03 PM
I was trying to look at the whole picture. Crane, Mallory, Jacobs, etc. all have ignition systems I can use. I have always had good luck with MSD, and that is the brand of crank trigger I have.I want to know if anyone else is doing this, what is your setup and want to know the good with the bad. I looked at the MSD 7 and up but that seems more race to me, would it work on the street?Right now it looks like the 6AL with the timing computer. The one with the three adjustments, for when the timing starts, how much timing , and how fast it gets there.The next one up you can plot the curves on the individual cylinders, but I don't have a laptop. They have a programer but that gets back todo I really need all this? Without some kind of timing device, the timing would not move at all Doug
Old 07-10-2004, 10:18 AM
harry k's Avatar
ok guys just little humuor here ,according when Goatey69 mentioned when he checked MSDs website products and said that brought up more questions than answeres, it stands for
"MULTIPLE SALE DISTRIBUTION"
cuse when you buy one box you have to buy following one after one and on on !!!!!
anyways i use em all and they are good products ,with crank trigger ,use the timing computor which gives you a starting retard,then advance at luanch ,and then when you hit high gear will give you retard .
Old 07-10-2004, 05:49 PM
Thanks harry k. I see the humor, now. That is the way I was going to go but wanted other input before I layed down the cash.With a stick car how does the computer know when you are in high gear?Or an auto for that matter. Again thanks for the input. Doug
Old 07-10-2004, 06:11 PM
WARPed's Avatar
WARPed WARPed is offline
I run the MSD crank trigger with their programmable timing computer in my 69 GP. First you have to lock out the distributor so it will no longer have any control of timing, then you will set your total timing to whatever your motor likes (mine is 34*). Once that is determined you can then go about setting the total amount of timing in the box (this controls your initial timing), rate of advance (slope) and what RPM you want the advance to begin. It is all there in the docs; I had to read them a few times before I got it all figured out.
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 07-10-2004, 06:17 PM
harry k's Avatar
Goatey69:for auto trans ,you will hook the high gear retard activation wire to 3rd gear detent on shifter,microswitch type
i would asume same for stick trans also ,havent seen any cars around here in my hometown that race at track with crank trigger and also stick,next time around if i do i will keep an eye on his set up !
Old 07-10-2004, 07:59 PM
Thanks for the info.I am getting a better understanding of whats involved with this setup.I'll have to look at MSDs website again. I was looking into a Tremec 5 spd. so figuring out the high gear activation wire is one more issue to iron out. If I keep the BW ST10 it won't be a big deal. Thanks again Doug
Old 12-04-2005, 06:07 PM
harry k's Avatar
GOATEY69:did you get the crank trigger yet ? if yes,whats your feedback?
Old 12-05-2005, 05:33 PM
cgeise's Avatar
cgeise cgeise is offline
69 -- I Have had a fair bit of experience with the MSD programable 7 -- the problem you will run into is that none the setting in these box's has a throttle/ vacum reference-- that I know of -- they are rpm dependent for there timing curve -- that is why a vacuum advance works so well on the street -- it is much more flexible for conditions used on the street ie; high timing at cruise-- drops back at full throttle at low rpm/vac. -- just something to think about -- maybe a good -- well set up HEI -- and forget the crank trigger for street -- unless 90% of the driving is at the track
Old 12-06-2005, 03:01 AM
Jack Gifford's Avatar
Jack Gifford Jack Gifford is online now
formerly 'Pontiac Jack'
Originally Posted by cgeise
... MSD programable 7 -- the problem you will run into is that none the setting in these box's has a throttle/ vacum reference...
FYI- the Crane timing module does allow for a vacuum advance function, via an input from a MAP (manifold absolute pressure) sensor. But the only adjustment provided is a selection between 10 or 15 degrees (crankshaft) of vacuum advance. That's one reason I bought the Crane, since I really want a vacuum advance on the street. Unfortunately, the engine isn't done yet, so I can't comment on the performance of the Crane box.
