Old 07-30-2004, 10:34 PM
Mo's Avatar
Mo Mo is offline
Can an early 421 sd crank work in a 70 455 block using an aftermarket SFI balancer and 70 timing cover. I have heard these are a short snout and can have issues with balancers. Thanks
Systems under stress fail catastrophically
Mo's Avatar
Mo Mo is offline
Old 07-31-2004, 08:01 AM
tom s tom s is online now
no issue with a short snout,there is a issue with a long snout and a early balancer.Tom
Old 07-31-2004, 08:19 AM
Mo's Avatar
Mo Mo is offline
Thanks Tom, just trying to avoid any major problems mixing parts. I'm not real familiar with early 60's Pontiac SD parts and what they will or will not work with. Anything else I need to know before building a 440 using this crank? Thanks again
Old 07-31-2004, 07:08 PM
crank register should be checked for your flywheel.Tom
