boboh1, If you are sure that the leak is from the vacume modulator at the shaft area, remove it and check to be sure that there is not a second O-ring inside housing.As mentioned in the earlier post, check the spring clip direction. If modulator checks good and there are no extra O-Rings, clean the shaft of the modulator and the housing. Apply a small amount of form a gasket around the seal area. Install it and let it dry for about 1 hour.
