Old 06-11-2003, 04:10 PM
80TA 80TA is offline
Well know this is the race forum but wondering if some of you guys drive your cars with racing type rci
fiberglass buckets .Are they ok for an hour or so on the street..how about a two to three hour trip.?? Or can you just throw some pillows on there. I like the way they look and they are light.My car is mostly a street car but will see some track time..probably only two or three times a year max.
80TA,pontiac 400,edelbrock carb,accel wires,dual exhaust,dynomax mufflers,no cats.
CE subframe connectors.
99TAWS6 ..lots of mods.
80TAWS6,400,edelbrock 750 carb/performer rpm intake/crane cam and lifters,/magnum 1.52 rocker arms/comp pushrods/arp rocker studs,cloyes double roller,crower valve springs,ias shocks,msdl wires,dual exhaust,flo pro mufflers mufflers,turbo 400, 2400 nitrous holeshot,3.42 strange gears.
Old 06-11-2003, 04:19 PM
wtakanabe wtakanabe is offline
After about a half dozen trips down the 1320 I take two advil for lower back pain before heading home and meeting the wife.
Old 06-11-2003, 04:29 PM
WARPed's Avatar
WARPed WARPed is offline
I don’t think I could last more than an hour on the road in my RCI seats. Now if I was 18 again….
with out questions there can be no answers
1969 Grand Prix
[email protected](1.358)
[email protected](1.342)
WARPed Tepee Forums
[email protected]
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
Old 06-11-2003, 07:47 PM
basketcase70gto basketcase70gto is offline
I don't think they are too bad. The trick is to get the angle right so you sit comfortably and slip a 1 1\2 inch strip of soft foam between the seat and cover. It really helps alot.
Old 06-11-2003, 09:58 PM
SLOW 77 SLOW 77 is offline
Exactly what he says. I sit in mine all the time, hour or two no problem, I actuall like the contour, but I did add some foam to the inside of mine.
Old 06-12-2003, 04:37 AM
Gooatee's Avatar
Gooatee Gooatee is offline
I will add a third to that, mine are great now that I have them mounted at a comfortable angle and added a little padding!
Old 06-13-2003, 03:46 PM
SupergasDil's Avatar
Hi Al,
I had a lower lumbar disc fusion 2 years ago on 2 levels from a work accident. I have the RCI buckets in my pro streeter which is a pretty solid ride to begin with, 4 link and coil overs on a tube chassis. Not much forgiveness. I drive this mother everywhere. They aren't Caddy seats but they do me and my back ok.
Oh, RSB, You're wife should be the one taking the Advil knowing that you're coming home!
Old 06-14-2003, 05:30 AM
getrich64's Avatar
getrich64 getrich64 is offline
Had a set for a while in my 64 goat. Backs of seats came way up towards roof. Little difficult on the visibility for street. Kinda looked like two tombstone heads sticking up!...lol But the comfort level wasn't all bad......
Rich
64 GTO street car
11.50 @ 119+ mph
pump gas tri-power
