We'll as you all know I installed that other cam and wasn't too impressed with it as it put my car out of its power range ,but on the recommendation of Mr.Hand I reset my centerline to 106 instead of 108 1/2 and installed rhodes lifters...I didnt take it out to the track or anything ,but I did take it around the block ...Roads were wet so couldnt get a good feel but all I can say is wow!!! It idles now with 14 inches in drive where before it had between 10-8 inches!And it feels much more responsive!!!I can hardly wait to try her for a full run!!
Thanks Jim!!!
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,[email protected]@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, [email protected] [email protected] M/T 275/60 ET SS Drag Radial 2024(Pontiac 505) 1.25 60 ft, [email protected], [email protected].... 275/60 Radial Pro's |
Thanks Jim!!!
I'm almost 11's with that grind (2802) right? I'm 1100 lbs less than you are. You'll be 12's.
"For some reason a glaze passes over people's faces when you say "Canada". Maybe we should invade South Dakota or something."
Hey Doug its the wolverine 1096 same specs as your 1175 ,112 LSA, 2802 is 114....12's hmmmmmm maybe some day once I get it all figured out,lol.....I think I will need the stall loosened up to about 2600 or so then it should be a romper
Darby, I went my fastest with a stock converter. The rhodes should give you pretty good bottom end to launch the "Titanic".
Don't know if I have the problem solved yet, but I did set the engine back in the engine bay this weekend and am going there today to bolt it all up and get it running. Can't help thinking that it's a fuel problem that caused detonation. Good luck going low low 13's.
And I had to hear about here on the forum... no e-mails about how excited you were....LOL.. Just kidding, Grand!! Glad to hear that you are happy now... had me worried a for awhile there! Jim
Doug.. .let's get that monster running again!!
1965 GTO Hardtop - Fontaine Blue, Blue interior, 389 Tri-Power, 4 speed, 3.36 posi, Rally I's |
Jim, It'll be growling by days end!
Very
'72 LeMans 2Dr Hardtop My first car, purchased in 1980 468 Stroker / KRE 315 / HR cam by SD Performance, Tremec TKO II 5spd --------------------------- '96 Corvette Grand Sport (#470 of 1000 built) Mildly modded LT4, 6spd --------------------------- '07 Corvette Z06 Mildly modded LS7, 6spd --------------------------- '67 Chevelle Convertible LS6 (405HP Z06), 700R4 |
Thanks Guys
