Old 01-30-2004, 11:12 AM
miketgto miketgto is offline
trying to verify if my ws engine is original.car build date 03a first week march. block cast date c865 march 8. tripower stated in another post that march april cars had very close dates.guess production was in high gear.also if anyone can help with acc codes. i know 5n was for gto,
car was built in pontiac.
line4 E 2LGPR
line5 4F 5NW
LOWER RIGHT CORNER 19-1W
line4 E 2LGPR
line5 4F 5NW
Old 01-30-2004, 03:02 PM
engineer engineer is offline
info is in various manuals, aftermarket books or can be purchase now on a CD. Then you will have all this info and more.
Old 01-30-2004, 07:14 PM
orange69 orange69 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by miket3x2:
line4 E 2LGPR
line5 4F 5NW
LOWER RIGHT CORNER 19-1W<HR></BLOCKQUOTE>
I'd say the engine and the car are not kosher,to me it seems the car was built the first week
and the engine was cast the second, and there should be a week between casting and assembly, in pontiac mich. and Kansas built cars. If you went by dates the engine was cast after the car was already built.
e= softray glass, all
L=4spd floor shift
g=console
p=radio
r==rear speaker
4F=outside rear mirror
5N=gto
w=deluxe seat belts
I'm no numbers expert but thats what it appears to me.
NOOOOO! it's not a freakin' Chevelle!
Old 01-30-2004, 07:56 PM
Jerry H.'s Avatar
Jerry H. Jerry H. is offline
The way I understand it, that could very well be correct. Example, if February 28 was on a Monday, that week would be the last week of February. Then the next Monday, March 7, would be the first week of March. Then if the car was built on Friday, March 11, and the engine could have cast on Tuesday the 8th. Very close, but possible.
Old 01-31-2004, 04:32 AM
trying to verify if my ws engine is original.car build date 03a first week march. block cast date c865 march 8. <HR></BLOCKQUOTE>
I have a 65 with just a 4bbl that has never been touched. The motor is locked up the trans is in the trunk, and it's so rough it's a parts car, but it matches completely right down to the plug wires. THe closest part/cast numer is 2 weeks prior to build week. I checked my 66 and it's the same way. One car built in Kansas other in Pontiac Mich. SO i dont know, it sounds too close to me, but anything could happen. LOOK around the site for Einstien, he has helped me, and he is very knowleable on build and trim tag stuff.
Old 02-04-2004, 03:20 PM
tripower's Avatar
tripower tripower is offline
Mike, I'm almost sure you have the original motor. Just double check the other date codes on the heads to verify.
During the Spring of 65, the Pontiac Michigan plant was on overload. Motors were cast the same week and at times the same day as the trim tag was stamped.
I have verified this with five original, 65 GTO’s I have come across including mine. I was skeptical too when I looked at mine a few years back. I have a 4th week in April trim tag date code and an April 28, 1965 (the fifth week of April) engine block cast date. I know I have the original motor because how well the car is documented and the fact that it is verified with the Protect-O-Plate.
I started asking around and looking at some of the big shows at original cars to see if I could find others like that. I found 4 other cars with these the same issue, all of them where Pontiac, Michigan cars. The owners were sure they were the original motors.
I’m sure you can find some other owners on here with the same issue. Maybe some others on here can post their numbers to see what we get. Keep that motor!!!!!!!
Norm J
Old 02-04-2004, 05:30 PM
Mike Moore Mike Moore is offline
My 65 Rag has these numbers:
Block:L14, Dec 1 1964
Left Head: L84, Dec 8 1964
Right Head: L114, Dec 11 1964
Intake: L44, Dec 4 1964
Data plate: 12C, Third week of December, December 13th - 19th. Its a Pontiac MI car.
Mike
