Old 08-24-2004, 06:32 AM
"Guy
Send a message via MSN to
Which dia. full exhaust, 2-1/2" or 3"
406 ci
292h cam
#16 heads,ported,filled,ss valves
comp. 9.7
headers 1-3/4, 3"collector
modified rpm intake/Qjet carb
curved hei/msd 6al
4spd/3:55 gear
Will the 3" kill low end torque?
"Guy
406 ci
292h cam
comp. 9.7
curved hei/msd 6al
4spd/3:55 gear
Old 08-24-2004, 06:42 AM
Banditone Banditone is offline
Good question--I was thinking of ordering the 3 INCH system for my 77 SE T/A --455 .030-- HORACING RAM AIR IV grind cam-headers etc. will be adding a BM HOLESHOT conv. is this a good converter with a 3.23 gear.
Old 08-24-2004, 06:43 AM
David Jones's Avatar
2 1/2 is plenty big enough. With that cam I'll wager you need all the low end you can gather.
Old 08-24-2004, 09:47 AM
67 455 Bird ragtop's Avatar
67 455 Bird ragtop 67 455 Bird ragtop is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by David Jones:
2 1/2 is plenty big enough. With that cam I'll wager you need all the low end you can gather. <HR></BLOCKQUOTE>
I was thinking with the specs below I should go with a 3". The one thing that will probably change will be a set of KRE heads.
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
Old 08-24-2004, 08:41 PM
71 formula 71 formula is offline
I may be wrong but i thing that header size is more important than exhaust size. Besides with a normal bent exhaust system 3 inch usually bends down to 2 1/2 in the turns. Even with 3 inch manrel bent systems i have never seen a loss in 400 ci and up motors especially with ported heads. Beside if you ever want to upgrade the motor in the future you don't have to buy another exhaust system.
Old 08-25-2004, 09:33 AM
quicksilver97ta's Avatar
"Cut-outs" or "dumps" work great on a street/strip car IMHO. There are quality electric ones available now. You could wire them with a WOT switch for hands free operation and stealth at the lights.
Old 08-25-2004, 11:02 AM
Larry Navarro's Avatar
I use the Jim/Tom Hand deign....
from the header collector; 3" with X-over, to 3"x2.5" Flowmaster reducers in front of 2.5" inlet/outlet mufflers, to 2.5" tailpipes.
'79 T/A
Old 08-25-2004, 04:20 PM
krisr's Avatar
krisr krisr is offline
I have a pretty much identical setup except i'm using the normal Performer, not RPM.
I opted for the 2.5" system with X to retain some low end, but with a 5speed box, there is plenty of gear there so getting it to rev isn't hard either.
Unless you're in the 500+HP range, I wouldn't bother with 3". Tighter clearances getting the pipes over the diff etc..
Old 08-26-2004, 04:23 AM
Cliff R's Avatar
Cliff R Cliff R is offline
I use 3" pipes off the collectors, 3" H pipe into two chamber Flowmasters that are blown out to 3" on the inlet side. They exit into 2.5" full length tailpipes. Non of the pipes are mandrel bent so one would think it would be somewhat restrictive. Even so I've ran [email protected] with this set-up......Cliff
Old 08-26-2004, 05:15 AM
"Guy
Thanks for info!
I have a 2-1/2 custom made set-up, all flanged to ease takin in and out. The X crossover was made straight so when you look thru it at any end it's looks perfectly thru 2-1/2"s. I was going to fit it to my Z71 getting rid of the cats...maybe later? I read somewhere(Carcraft) if you take a vacuum gage to the exhaust to see if big enough? If it makes a sertain number of "s of vacuum or more the pipe should be bigger, I'll look for it again. By the responces and the exhaust pro that built it I sould be able to throw quit alot of HP to it.
Thanks.
Old 10-07-2005, 08:21 PM
Lerry: The Body Ventura..'s Avatar
Lerry: The Body Ventura.. Lerry: The Body Ventura.. is offline
Send a message via Yahoo to Lerry: The Body Ventura..
My opinion(for what it's worth?) I would go with the three inch. Your collector is three inch(even flow). Your muffler will make up for the back pressure you need(depending) with your set-up. Going to the three inch exhaust, you will then be also ready for upgrade of engine flow in future. Unless of course you plan on staying in the perimeters of where your at?
Old 10-07-2005, 08:31 PM
shaker455's Avatar
Is that cam the 292AH-10?
My friend has it in his 70 GTO and it rocks!
I'd say go with the 3"
What mods did you do to the RPM intake?
