Bob, thanks.I will try the loctite then. There is enough thread going into the block so that won't be a problem.
Locktite or epoxy.
The main caps typically are removed with the engine out and the cap is positively located so using an epoxy or locktite to lock the studs in the block should not be an issue. As long as the proper thread depth is achieved, go for it. Another deal is to check for the stud (OR BOLT) bottoming in the hole which WILL break stuff when torqued down if not enough clearance. JMO! Tom V.
Is this a good point to "Sell you all on Rear Main Cap Bolts...Has anyone seen the pair fail?
"Trow me a...Bone here...need the info." HIS
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
I've bought and install Main Studs. Perhaps the Middle Cap Bolts would benefit, but the 4-bolt Outers, and the Rear Mains seems moot to change.
HIS
