Old 05-14-2004, 08:22 PM
WillV's Avatar
WillV WillV is offline
Hey Guys..
This is probably a long shot, but I'll ask anyway. Does anyone know how to remove and replace a power window motor off a 1997 Pontiac Transport-Montana? It stopped working, I have the whole door panel apart, tested the motor and it's dead. I have the shop manual, but it's not quite clear how to go about removing it. It mentions something about unloading the spring. Sounds complicated so I may have it done for me, but if anyone has ever tackled this job, please help. Thanks!
Will
ps: this is for the front passenger side.
Will
WillV's Avatar
Hey Guys..
Will
Will
Old 05-15-2004, 06:02 AM
TIAUTOMAN TIAUTOMAN is offline
you have to tak the regulator out to do the job
once its out its pretty self explanitory
about unloading the spring, use a vice and be
very carefull, if you remobe the motor and
dont release the spring ( or hold it in place)
it can take your fingers off
Drill a hold throug the regulator and the arm
and slide a bolt in it, it pins the 2 together
and it wont move
put a nut on the other side for security
then drill out the rivits and reiinstall new motor
Old 05-15-2004, 12:49 PM
WillV's Avatar
Thanks Travis.. I'm waiting for the motor to come in and will try it then.
Will
Old 06-14-2004, 09:01 PM
David Holmberg's Avatar
It's very close to this, but you have more room.
I just did the motors in the wifes Trans Sport...
http://shbox.com/page/windowmotor.html
Old 07-08-2004, 09:20 PM
einstein's Avatar
einstein einstein is offline
If you don't mind me hijacking this thread with a related problem, I'm replacing the power window motors in a 92 Sunbird convertible.
I've often heard about the "three large rivets", but I drilled five big ones to cut the motor/regulator assembly loose from the door. However, I couldn't get the regulator out of the door - I just removed a couple of screws to release the motor from the reg, but it popped the spring, and it appears I'll need to get the regulator out of the door.
There's a plate on which the motor/reg was attached, and the plate appears to cover the only hole large enough to get it out. But it's also riveted in with 19 rivets.
Am I supposed to remove this plate?
