I have been keeping an eye open for a rebuildable cheap TH-400 to go in the GTO (Back-halved, full cage car, hoping to see the 10's with minimal spray).
Found one locally but it has the long tail shaft, from a 70's Bonneville. Have seen warnings on other posts here before about these not fitting the stock crossmember on the A-Body, but is there anything else inherently not "performance use friendly"??? Fabricating a new crossmember is no biggy and a custom driveshaft is in the plan anyway. So any other reason not to use this one as a starting point for a manual-shift/non-trans-brake performance rebuild? Will the shorter drive shaft adversely affect some angles with the pinion an such? Thanks
"Nothing Beats an Ol' Goat." |
I've heard you can change tail shaft and tail housing to make it a short tail to fit your A-body.Just a TH400 for a big car.
[email protected]
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
if your going to have it rebuilt than have your tranny man change it over to a short tail
all you have to do is change the output shaft and the tail housing I do this alot easy to find long tails
If your not first your last |
I ran one of these with out problems in a 70 A body. Moved the crossmember back and shortened the driveshaft.
Shorter driveshafts are more stable.
So, either way Short or Long tail. HIS
95 Towncar that needs more TQ. Sold 2023: 12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
We just built a th400 for a customer who had a 67 long tail trans. Nothing more than changing the output shaft & housing.
Another Red Light Nightmare ![]() 1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw 1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project. Semper Fi |
the short shaft changes the pinion angle
MY 70 GTO THAT I HAVE OWNED FOR OVER 18 YEARS HAS THE LONG TAIL SHAFT TH400 IN IT. DON'T KNOW IF IT WAS FACTORY OR NOT.
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by 50tooslow:
MY 70 GTO THAT I HAVE OWNED FOR OVER 18 YEARS HAS THE LONG TAIL SHAFT TH400 IN IT. DON'T KNOW IF IT WAS FACTORY OR NOT. <HR></BLOCKQUOTE> Not factory. All A bodys that came with the TH400 had the short shaft.
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
Goatrider- I have a short shaft housing and shaft that I will trade you if you want.
buy using the long tail yes it bolts in with no problem just slid the cross memeber back on 64 to 66 will have to drill frame for short or long tail 67 up has holes already there you will have to shorten the driveshaft I think by 3 or 4 inches have to measure lenght differnce between the trans you have in there now and the lenght of the the short tail 400 is an 1 inch longer than the 350 300 or powerglide using the 400 long tail by doing this you will also be changing the drive shaft angle
Thanks for the replies everyone!
Think I will snag this one for $50 then and switch to the short housing at time of rebuild, that way I can use my stock crossmember and keep the better pinion angle. Bruce - I will take it apart per my service manual and bring the shaft and housing over to trade you (along with that rum) when we do that other deal in the cool weather. Thanks again, John
I will sell you a shortoutput shaft and tail housing for $60 to fit a BOP. Thats all you need for the retrofit.
ET 12.504 MPH 107 3940 lbs |
