Old 02-14-2004, 04:07 PM
GTO JOE 64 GTO JOE 64 is offline
OK here is the question? I have a 64 GTO it was running hot at Idle, but would run fine while I was driving. well today I started it up(after three months of sitting in the cold Chicago weather) and the water pump was spitting all over the place. So what water pump do I go with, the cast or the stamped. and where do I get it?
Thanks Joe
Thanks Joe
Old 02-14-2004, 08:49 PM
wheelspin's Avatar
Joe,
Try our host PY, who stocks both types with the cast impeller favored by most Forum members.
Les
66 GTO Sport Coupe,455/trips,700r/2500stall,12bolt/3.08,1.79/13.01/104.5
68 GP daily driver and 2004 Route 66 Tour participant under restoration
Better lucky than good
Les Iden
Old 02-15-2004, 09:57 AM
Thanks Les, but I cant seem to find it on the PY fourm.
Joe
Old 02-15-2004, 11:56 AM
Verdoro 68's Avatar
It's a lot more expensive than the standard pump but you could also consider going with a Flow Kooler water pump. I bought one for my '68 and I'm pretty happy with it. I've never seen my temp gauge above 180 since I installed it. I have a '69-up timing cover so I got the aluminum pump. The '63-'68 pump is cast iron.
Ken
'74 Ventura 350
'69 AMC Javelin SST
Old 02-15-2004, 08:16 PM
wheelspin's Avatar
Sorry Joe,
Forgot that there are only rebuilt or nos waterpumps (not sure if they are cast or stamped impellers) available for the early 8 bolt pumps like yours (64-68). On my sig GTO below, I fitted a 69 timing cover to allow using the 11 bolt pump.
The comment re Forum preference for the cast impeller applies to the later 11 bolt pump.
Try Autozone and inspect the available cores or have yours rebuilt, as an alternative.
Les
Les Iden
Old 02-16-2004, 07:27 AM
Bill H's Avatar
Bill H Bill H is offline
8 Bolt water pump with cast iron impeller. I got mine from Kragen Auto. About $24.00
http://www.partsamerica.com/default.asp
Cardone 58299
67 GTO HT
1968 400 Engine YE
TH-400
#13 Heads -J069
Q'Jet .
8.2 Eaton Posi/3:55
Old 02-18-2004, 06:24 PM
BOB VIDAN BOB VIDAN is online now
The correct cast impeller for 64-5 is much smaller then the picture above. I used one similiar to the picture on my 65 post and could never get it to run cool. Changed to the smaller impeller pump, never had a problem since. The larger impeller moves the water too fast through the cooling system and does not allow it to cool correctly.
Practicing social distancing for 65+ years
Old 02-18-2004, 06:49 PM
Thanks guys for all the replys, so now I am really confused, so what one did you go with Bob? and what do you think of that flow kooler? and does it matter what one I put on so I keep my car original?
Thanks Joe
Old 02-19-2004, 01:07 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
Hey Les -
So you say the PY water pump for the 11 bolt has the cast impeller.
Did you notice a difference after putting it on? I'm asking because my new motor runs 200-210 all the time, even when going down the freeway when it's 50 degrees outside, or idling. I don't care about the 200-210 degree part, but I'm wondering what will happen when summer comes around.
TIGER EFI - Electronic Fuel Injection for the Traditional Pontiac Engine. [email protected]
The point to life isn't necessarilly the decimal.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
Old 02-19-2004, 01:09 PM
vidguy's Avatar
vidguy vidguy is offline
Heck, I would say with an inexpensive and relatively easy to R&R part like a water pump to not worry about original right now. Get what works well and fits easily.
outside differences wouldn't be too noticable anyhow and the inners not at all. And you can spend $50.00 and a couple hours when you want to sell it as numbers matching car later.. (but you wouldn't sell it right?)
"Put your Finger right here"
James
Work
'67 GTO Convertible "Koerner Built 413 500 hp with a Victor!.. I'll run a stock intake."
'75 Formula 400 - Daily Driver -
Running with my Home Built 455 and TH400
Details here:
http://forums.maxperformanceinc.com/...d.php?t=588372
Old 02-21-2004, 10:11 AM
VERDORO Thanks for the advice, but you say that you are pretty happy with it, but my question is are you real happy with it?
Thanks Joe
Old 04-11-2004, 11:59 AM
I am going to buy the water pump from PY for my 64 the qustion is do I need the diveder plate also?
Thanks Joe
Old 04-12-2004, 06:37 AM
JoeF's Avatar
JoeF JoeF is offline
You won't know for sure if you need the divider until you open her up and check the old one. The new ones from PY are stainless and should last a good long time if you decide to change it. I guess it all just depends on whether or not you want to have all the parts you might need on hand when you start the job. If you don't mind waiting a few days to finish the project, you can get started and order the divider after you get a look at the old one.
'67 GTO Conv 400 TH400
Old 04-12-2004, 06:40 AM
JoeF's Avatar
By the way, read this thrtead before you start:
http://forums.performanceyears.com/g...11&m=958104692
Should answer a lot of questions.
