Old 06-04-2004, 04:38 PM
66 tempest's Avatar
66 tempest 66 tempest is offline
how do i find out what type of transmission i have? will it say on the transmission pan?
66 tempest's Avatar
Old 06-04-2004, 08:02 PM
No it wont.
If the pan is square with the corner cut off and it has a cable running to the throttle you have a Turbo 350. If the pan is odd shaped and it has a electic kick down then it is a Turbo 400. If it only has 2 foward speeds then it is a Super Turbine 300.
Old 06-04-2004, 09:15 PM
cuz68's Avatar
cuz68 cuz68 is offline
Try here, http://www.teufert.net/trans/tranny.htm
Cuz68
Old 06-06-2004, 01:14 PM
66 tempest's Avatar
does anyone here have the turbo 350? could you please post a pic of how the kick down cable is hooked up, either gas pedal or carb throttle arm. also i removed the cable from mine, it would not go into the 3rd gear manually, i measured it and it is 32 inches, where can i get the correct cable? does it really matter on the lenght of the cable and if so why??
thanks
Old 06-06-2004, 05:33 PM
The length of the cable will depend on how you want to hook it up since it is not an original application. Some applications had the cable hooked to the carb, and others had it hooked to the gas pedal.
Old 06-07-2004, 07:29 AM
66 tempest's Avatar
i have no cable hooked up to either location. i know it has this cable, just not hooked up, where can i get the cable bracket to the carb
Old 06-07-2004, 11:52 PM
urhere2 urhere2 is offline
Lokar makes a nice cable and bracket setup. I saw it at a friends hot rod shop on a custom truck. He had it hooked to the carb on the drivers side along with the throttle cable.
