Old 05-16-2003, 07:36 PM
pontfan pontfan is offline
i bought a long block it is an 71" but i could not find the cast# in a book the # is 481990 the last # was hard to read i think it is a "0". it has 4X heads on it but front and back bolt holes for the exaust are not drilled on both heads was there a reason for this? Thanks for any help!
Old 05-18-2003, 08:31 PM
johnta1 johnta1 is online now
481990 is the block casting code for a 1971 350.
Was there a reason for the end holes not being there? Not really. Probably so the factory could save 2 cents.
johnta1
Old 05-19-2003, 08:59 PM
thank you. i was thinking about getting headers and was sure if i would have drill and tap the bolt holes?
Old 05-19-2003, 09:43 PM
If it's got the flange there,just not drilled,go ahead and drill and tap it.
If it's missing the flange altogether,look up Paul Spotts at Spottsperformance.com
johnta1
Old 05-23-2003, 01:28 PM
thank you! i curently have a points ingition and want to change it to hei or pertronics magnetic pick up conversion kit do u know anything about these kit? or is hei better? i will have to check the heads for the flang, but i'm pretty sure there. thank u again.
Old 06-03-2003, 09:27 AM
Personally I would go with the HEI.
The Pertronix seems to be ok,except they make 2 versions.The one with the lobes is better I think.
johnta1
Old 06-21-2003, 09:28 PM
thanks i went with the HEI and the engine runs a smoother and has more power.
