Old 05-19-2005, 12:07 PM
71 T/A 71 T/A is offline
On my 69 GTO, the front 1.25" sway bar I bought from PY touches the idler arm. I hear a metallic noise on big bumps but otherwise, it seems okay. Has anyone experienced this? Is there a way I could gain a little more clearance?
Old 05-19-2005, 03:08 PM
gtoformula's Avatar
gtoformula gtoformula is offline
The front sway bar should not be anywhere near the idler arm while the car is in a straight line. It may get close when you are making full lock turns. Where does the bar hit the idler?
Old 05-19-2005, 03:50 PM
It hits the right side (front edge) of the idler arm. Actually it only hits when I'm turning the car as I back out of my driveway which has a bump in it. The bar never hits when I'm traveling straight.
Old 05-19-2005, 03:53 PM
pro-tour79's Avatar
pro-tour79 pro-tour79 is offline
is the car lowered at all ? I think your end links may be too long.
www.pro-touringf-body.com
Old 05-19-2005, 07:28 PM
The car isn't lowered but the front springs are original and they sag just very slightly. But the end link bolts are a tad long. They're aftermarket parts.
Old 05-20-2005, 06:09 AM
gtoformula's Avatar
So the idler arm is contacting the sway bar at the end that bolts to the centerlink?
If that is the case then turn the steering full lock and look underneath to see where it contacts.
pro-tour79's reply could be correct. If the links are too long then get a different set of bolts and sleeves. If you just cut the sleeve then you may not have enough threads on your current bolt to adequately compress the bushings. Reducing the sleeve length will lower the sway bar and might give you enough clearance.
Old 05-20-2005, 01:45 PM
The sway bar's contacting the idler arm at the ver bottom in the front. Problem is the bar would have to be lowered about two inches to clear it.
Old 05-20-2005, 08:43 PM
paul6874 paul6874 is offline
I get it. I only read your post under general tech. I misunderstood your problem. I installed a 1-1/4 bar from a 78 or 79 trans-am and had trouble with the tierod. Sorry, I assumed that's what you meant. Your problem is with the front bushing. you have it mounted too far back. If you are trying to use the stock bolt holes, you need to grind the slots as far in towards the bushing as possible, and use socket head bolts. Note in the pic that I had to grind the washer flat on the back edge.
Old 05-20-2005, 08:48 PM
From the top.This is how much clearance you should have. The idler arm does not move at this end. If you are only hiting it at a bump, check for loose bolts or ovaled bolt holes where the idler attaches to the frame.
Old 05-20-2005, 08:50 PM
This is where I thought you had a problem when I suggested taller spacers.Hope all this helps.
Good Luck !!
