Old 09-19-2002, 07:30 PM
Gman6900 Gman6900 is offline
87 cc Eheads with sharps rollors.
  #42
Old 09-19-2002, 08:29 PM
Ken K Ken K is offline
I have a set of those new Australian iron heads. That is all I can divulge at this time.
  #43
Old 09-19-2002, 10:28 PM
boykoman boykoman is offline
614 Round ports flow 283@400 lift 308 @650.I feel these heads I own will beat any edelbrock head motor to motor no nos in a heads up match!!I.e same weight vehicles.Warpath Performance did these heads!!!
  #44
Old 09-20-2002, 12:08 PM
critter's Avatar
critter critter is offline
#16 round port SD heads. No porting. Some casting flash cleaned up and exhaust ports polished. Unknow flow numbers (but not much off stock, I'd imagine) Ultradyne 280/288 cam.
8.31 in the 1/8th at Butler's this year
(Yeah, it's slow but I can run 87 octane and cruise all day with those 3:08 gears)
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
  #45
Old 09-20-2002, 12:40 PM
dammen8's Avatar
dammen8 dammen8 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by boykoman:
614 Round ports flow 283@400 lift 308 @650.I feel these heads I own will beat any edelbrock head motor to motor no nos in a heads up match!!I.e same weight vehicles.Warpath Performance did these heads!!!<HR></BLOCKQUOTE>
Hey I am just a few hours from you and we just happen to have a race this weekend if you want to show up, I will show you what my e-heads will do....
Chad
ND's fastest Pontiac (I think) and Minot's fastest street car (not like that means much)
[This message was edited by dammen8 on September 20, 2002 at 04:13 PM.]
3500lb 10.5" tire. [email protected] with a poor 60'
  #46
Old 09-20-2002, 03:52 PM
PONTIAC DUDE's Avatar
Nothing personal, but comparing E-heads to Steel heads with restricted workable passages, plus not having the flow capability to handle the newer better ground cams(and technology) to take advantage of the E-heads better flow capability is redundant. [img]/infopop/emoticons/icon_rolleyes.gif[/img]
I know, a run on sentance, but I had to get my point accross.
Never happen. That was then this is now. [img]/infopop/emoticons/icon_wink.gif[/img]
They were a good head in their day....... so were
flat head V-8's. [img]/infopop/emoticons/icon_biggrin.gif[/img] [img]/infopop/emoticons/icon_biggrin.gif[/img]
"If we can't beat the price.........we can match it."
http://PontiacDude.cc
  #47
Old 09-20-2002, 04:01 PM
Brian Baker's Avatar
Old street/strip...6X's milled to 86cc, home ported (230 cfm?), on a stock stroke 462.
New strip/street...62's race ported (254 cfm at .600" on a 4.151" bore @ 28"), on a 468 (4.25" stroke by 4.186" bore). These heads have gone 10.50's @ 126-MPH on a 400 in a 3400 lb. car, so we'll see what happens with the tubby T/A.
308cfm is 308cfm, it doesn't know what head it's flowing through. Can't use the argument about velocity either, E-head port side by side with R.A. IV port is close, ported ot not.
  #48
Old 09-20-2002, 04:10 PM
Brian, he didn't say that both heads had to flow the same. He is saying that his RA IV's will out perform Any E-head, without power adders in the same weight car. [img]/infopop/emoticons/icon_eek.gif[/img]
Not on this planet. LOL.
  #49
Old 09-20-2002, 08:14 PM
Hey Chad Dude what took you guys so long.I thought with that statement I made people would be all over me.Chad my track is open Sept 29 or Oct 6.You can show me what your heads can do.Your also welcome to stay at my house if you need a place to camp out at.My car weighs just under 3400 pounds.Remember no NOS.What does your car weigh?Im Manitobas Fastest traditionally powered Pontiac.(what ever that means??)Maybe we can have a title WWF match for the Northern title.Would be lots of fun if you came up.We could show some of the chebbie guys why we run Pontiacs.Hey hows Cory doing?P.S.Cant make it out to your track have to work this weekend.
[This message was edited by boykoman on September 20, 2002 at 11:35 PM.]
  #50
Old 09-21-2002, 08:48 AM
455T/A 455T/A is offline
E-heads are good but how much more than 308 can a set of street e-heads flow? Me thinks it might not make much of a difference.
  #51
Old 09-21-2002, 09:24 AM
Injun Injun is offline
Ported '71 #96s. 12.1X 10X mph. Pump gas is your friend.
1967 GTO HT, Tyrol Blue, 4sp, 54K original miles.
2002 WS6 Trans AM, Black, 6sp
1967 GTO HT, Tyrol Blue, 4sp.
Just sold my other 67 GTO
  #52
Old 09-21-2002, 11:04 AM
Tom McQueen Tom McQueen is offline
Edelbrock 73cc. Pushrods offset .250", 2.18" intake, 1.760" exhaust. Flow is 366/280 at .800" and 28". And these are going on my new street engine.
Check out my 70 GTO build;
http://www.yellowbullet.com/forum/sh....php?t=1148602
  #53
Old 09-22-2002, 07:37 AM
Larry Navarro's Avatar
torqjunki....call your office!!
how about a 462 and a set of d-ports flowing a measly 275cfm, a flat tappet solid, 3650lbs street car, running 10 teens in the 1/4.
however you slice it, iron vs. aluminum, its all in the way a port can efficiently flow the air.
  #54
Old 09-22-2002, 10:42 AM
Ive run 9.60s at 139 with a 1.29 short time in the bird no nos just a 462 with steel heads.This is a personel best for me so far and the air is getting colder!!.1/8 mile time was 6.12 and change.Hey Chad if you come up make sure you bring enough head flow.All in fun of course!!!
  #55
Old 09-22-2002, 08:57 PM
torqjunki's Avatar
torqjunki torqjunki is offline
boykoman...Very impressive!! Another lesson for the BIG NUMBER lovers. It should be no secret that our Pontiacs make much less HP than most of the turds we drag down the track. Same applies for big CFM numbers. I don't buy into the number crunchers who attempt to apply a mathematical equation using the max CFM of my cylinder heads to project performance levels. On a traditional Pontiac engine, more important factors apply.
#62 d-ports 270cfm @.500
10.25 @ 129 no NOS
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/[email protected] Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight.
  #56
Old 09-22-2002, 09:14 PM
Exactly look at Neil Owens,Bob Maxi,Nunzi,Mike Vocey,Mckinneys ect.Those guys haul a##.
  #57
Old 10-02-2002, 06:14 PM
Rockcrusher-M22 Rockcrusher-M22 is offline
So far it seems that everyone likes the E-heads or #16 d ports. Does anyone still run #12's or #48's. I loved my 670's that I sent to warrior racing for porting, but I haven't had the pleasure of experiencing the Edelbrock's.
  #58
Old 10-02-2002, 08:06 PM
WARPed's Avatar
WARPed WARPed is offline
IMO you can pretty much lump the #12, 13, 16, 48 and 62’s into the same category. The #12 and 48’s have greater value for the restorers of RAIIIs but other wise there are little if any performance difference.
Everyone, don’t forget to vote, survey is at the top/first post.
with out questions there can be no answers
1969 Grand Prix
[email protected](1.358)
[email protected](1.342)
WARPed Tepee Forums
[email protected]
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
  #59
Old 10-02-2002, 08:25 PM
Tim Corcoran's Avatar
#16's ported by Pete McCarthy, 2.19 Manley intake valves and 1.77 Ferrea exhaust valves. Flow sheets from SD Performance say they flow:
average of all ports on the intake side is 288.45 at .550 lift measuring at 28" of water. Best port flowed 290.60 worst port 286.30
average of all ports on the exhaust side is 194.6 at .600 lift measuring at 28" of water. Best port flowed 201.2 worst port flowed 188.10
The exhaust is a little weak but the intakes aren't bad for a D-Port [img]/infopop/emoticons/icon_smile.gif[/img]
Tim C
65 LeMans 11.06@121
Tim Corcoran
  #60
Old 10-03-2002, 06:12 AM
But look at the size of the motors they are running for what they are turning. We're not talking Small Blocks here.
These Pontiacs are pushing big Cu.In. #'s and are turning what, weigh how much, and with how much spent????????
Let's compare Apples to Apples.
I love Pontiacs but, come on....... if I had 474+ cu.in and am only in the 8's or 9's with how much spent!!!!!!!!!
You do need flow, just it all doesn't have to be a total at .700 lift, (ya need those middle #'s) but you still need flow to make big #'s,,,,,,,,, if your not running power adders. LOL.
Q-16 Norwalk
Qualifying [email protected]
2nd Round, [email protected] ...Radials... hard on the brakes, Ray. LOL.
