Old 06-11-2005, 12:10 PM
MRGTO2U MRGTO2U is offline
Hey guy's, my 68 Goat speedometer is jumping back and forth about 5-10MPG and making a chicking noise, that is the best way to describe the noise. Ho w do I take the speedometer out to oil or replace the cable? Does it come out forward towards the driver?
Under the dash its a pain in the A**.
Thanks for your help.
Old 06-11-2005, 03:55 PM
CDN2PLS2 CDN2PLS2 is offline
Reach up to the speed and undo the cable from the head,then pull the complete cable out of the casing.I just clean it and work white lube into it,then slide it back in.
Old 06-12-2005, 03:26 PM
1-GTO's Avatar
1-GTO 1-GTO is offline
Send a message via Yahoo to 1-GTO
There's a metal clip around the head of the cable that has to be pressed down to release the cable....and "Yes" its a PITA to crawl up under the dash!
GTO.....Gran Turismo Omologato,True Pontiac Excitement!
Old 06-13-2005, 10:17 PM
cuz68's Avatar
cuz68 cuz68 is offline
If it is your cable take it out from the tranny a lot more easy to do.
Cuz68
