Old 05-16-2001, 11:11 PM
GoGoat GoGoat is offline
My tach in my 66 GTO doesn't work. It worked 2 times in the past year for 15 seconds after I started it. Any suggestions? Also, can I remove this from under the dash?
66 GTO Conv Tripower 4 spd stock
67 GTO HDTP 400 auto stock
70 Judge 400 RAIII 4 sd stock original
69 Firebird 468 auto 28 option
49 F1 302 aod
49 F1 302 aod
Old 05-18-2001, 10:55 AM
John F Tary John F Tary is offline
Ref.your tach problem.Try the nice people at [email protected] seem to know the most about tachs and instruments in general.I had very good dealings with them.Good luck and happy motoring. J.Tary
Old 06-22-2001, 04:06 PM
Peter Serio's Avatar
The tach cannot be removed unless you take out the entire dash bezel and remove the cluster off of the back of your bezel. The tach can be repaired as they will go bad from age and not necessarily from use.
Peter Serio
Owner, Precision Pontiac
Peter Serio
