Old 02-06-2003, 07:17 AM
ascreemer68 ascreemer68 is offline
does anybody know the difference in lengths of the 68 stock water pumps as those from 69-72?
im having belt alignment problems and the squeelings killin me, .. worse than no heat!
stefan
http://www.stefanjames.com/goat.htm
stefan
Old 02-06-2003, 01:01 PM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
The problem is not the water pump, but the timing cover. 69-up are different than 68-earlier.
"once in awhile you get shown the light, in the strangest of places if you look at it right" - J.Garcia
Old 02-06-2003, 06:58 PM
Frank R's Avatar
Frank R Frank R is offline
If you are using a 1969 and newer timing chain cover with the longer waterpump you will need to use a 69-70 top pulley. The bottom pulley is the same. You also will need to use the newer alt.
bracket that goes from the waterpump bolt to the alt. it is differant from the 68.
http://ultimategto.com/rest05.htm
Old 02-07-2003, 06:30 AM
"If you are using a 1969 and newer timing chain cover with the longer waterpump you will need to use a 69-70 top pulley. The bottom pulley is the same. You also will need to use the newer alt.
bracket that goes from the waterpump bolt to the alt. it is differant from the 68."
ok, ... how do i know if im using the newer timing chain cover.. what are the differences?
thanks
stefan
Old 02-07-2003, 06:46 AM
RPM's Avatar
RPM RPM is offline
Send a message via Skype™ to RPM
Timing chain covers from 64-68 used the 8-bolt water pump. '69-79 used the 11-bolt water pump. If you have a pulley alignment problem you need the correct depth pulley like the above post said. You will also need a different alternator bracket (from water pump to the adjuster bolt on the alt) since the location it attaches to on the 11-bolt water pump is slightly more to the pass side than it was on the 8-bolt pump. These brackets are sold by PY, Ames, Year One, etc. Your crank, A/C, power steering and alternator pulleys can remain as is.
Here is a link to a page that will explain better:
http://www.hoigto.com/tech/pulley.html
Old 02-08-2003, 11:07 AM
cool cool. thanks guys.
