Old 09-23-2002, 05:04 PM
In the process of selecting a new cam. Brian and i have been EMail taggin each other fer a while, and he may have just the right cam specs for me but i would like to see what everyone thinks about a single pattern over a dual patern cam.
Which do you guys feel is better. Car is a 77 Ta with a 455. car will be a cruiser/Go to the track on weekends car.
All advice will be greatley apreciated.
Mike
Mike
Old 09-23-2002, 09:00 PM
takid455 takid455 is offline
Send a message via AIM to takid455
the cam should best fit your intentions with the car. being t hat you want to drive the car as well as lay some strips, i would go with dual pattern. comp cams Xtreme energy cams do a good job of combining the two. i installed the one closest to the RA IV cam and have no problem on the street and can still hang with the ls1 boys. also what tranny and gears are you running? they also make a difference. with a M/T a single pattern would do best do to the wide range of RPM's used. but check out comp cams.
1972 HO Trans Am auto White/white
1974 SD Trans Am 4 spd, no a/c dk blue/ white & blue
1978 Trans am gold/ black ,T56, t tops, EFI 474,
Build: http://www.pro-touring.com/showthrea...1978+g+machine
1999 30th Trans Am 6 spd, T top
